NM35 VQ25DET Camshaft Rattle Post Senor Replacement
Hi All
Just replaced the 2 camshaft position sensors on my old mans NM35 Stage (VQ25DET) and now the car is getting a rattle at circa 2000RPM from what appears to be the camshafts. I have read that this can be caused by using oil that is too thin, or the spring return within the variable cam timing assembly failing.
Prior to going down the path of the variable cam timing assembly, we will be trying an oil change but was also curious if maybe the replacement of the camshaft sensors requires a camshaft re-learn procedure and is there anyway to do this without a Consult 3?
Any assistance is greatly appreciated.
It's more a clunking sound than a rattle to be honest and happens randomly above circa 2000RPM. Car is running 10-40. From what I can recall, this has only come about post replacement of the sensors.
Engine performance still feels strong and there is no loss of performance from what I can gather.
If its a single clunk its going to be the cam advance.
If its a repeated clunk clunk then its going to be the mechanism.
I have changed my intake timing to advance earlier so i hear it when i put my foot down basically from idle it is quite loud and would sound like something is wrong id you didnt know what it was.
Just a quick update. I replaced the oil and for the first quick little drive the clunk didn't happen. Once the car warmed up, the clunk came back.
I then disconnected the passenger side blue cam plug and the clunk disappeared.
I am assuming that with the VCT not active (both blue cam plugs disconnected) there is no issue running the car ad there is just less power as the cams haven't been advanced. Thoughts?
Is the cam mechanism removal an engine out type job?
Edited by stealth01
Its fine and normal. If its the noise Im talking about,
The cams dont seem to advance initially when cold (i have found from my logs showing 0 degree across the whole rev range when first starting up).
I can try and record mine for you it sounds like a clunk almost like slack in a centrebearing noise.
When you disconnect the solenoid you are not activating the advance.  thats why it goes away.
Edited by m35stagea
The sound is something new and one that we haven't heard before. Doesn't sound like it would occur in normal operation given the nature of the loud clunks.
Has anyone tried the replacement of the VCT Cam and is it an engine out type job or is there enough room in the front of the engine to remove this when taking off the front engine cover?
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
    • I think he was only proposing to use the wire, not the sender. Simply because it runs from the right place to the right place. Personally, I wouldn't hack up the factory wiring like that. I'd just lay in the Defi loom.
