Hey ppls,
Well, I've made my kit up and it works great. Takes some tuning to get it right, but when it's right, it goes great.
Kit will come complete with two valve and check valve, as described in Autospeed articles Autospeed article
Valves will be mounted to a bracket, all you will have to do it mount the bracket and plug in your boost lines.
Price change : $130 (plus shipping which will be $15 anywhere in Australia)
I will require payment up front, and the kits should be ready in 7-10 days.
See attached pic for the example of what it will look like.
Current people in buy are
ADZMAX
SKYLINEGEOFF
CEREALKILLLER
BASS OUT
https://www.sau.com.au/forums/topic/47127-group-buy-pneumatic-boost-control/
Okay, I noticed the following.
The thing takes a little while to set up, but once set it says set.
Tranisent boost response, ie getting on the throttle in higher gears is much better, insted of slowly building, it just goes straight up to full boost.
First gear is not all that noticeable simply because my car revs out so fast in first anyway.
But spooling is definently quicker.
BASS OUT
Possibly interested...
Do you just mount in the normal position between the presure point and actuator? I'm a bit of a dumb arse when i comes to the mechanics of the turbo and am concerned i would not know where to install it...
So your saying the advantage is that the boost comes on quicker than a normal single stage controller? I read in your first page on this that it acts more like a Electronic Controller. Is this correct?
Regards,
Jeremy
PRICE CHANGE. NOW $130 complete
GOT SOME BETTER QUOTES FOR THE PARTS.
Need at least 5 people though.
If we get 10, then price drops to $125 each.
BASS OUT
I'm in for sure. These things are great and the theory is sound. The fact you can controll how quick and how strong boost comes on is awesome. I run a standard bleed at the moment and was keen to get one of these kits just could never be farked building it :)
This is a slightly neater way to do it Later on I put it inside the cold air box
http://www.skylinesaustralia.com/members/5...takes%20003.jpg
Hey Jay,
I notice you've got the upgraded pressure regulator there. Did it make a big difference in controlling boost? was it worth the extra $$$???
Zahos
That's a good question and something that I might investigate.
I drove to Bendigo and back today and had a lot of opportunities to play with the boost control, mainly slowing down to 80 and dropping it up to 110 (legal limit) to see what the boost does in each gear.
What I found is that the boost will spool to the set level (first valve) in first and second no problem, but then third gear, it would boost to set level and then drop right off, like the wastegate was flying open.
The boost would eventually build to the peak level, but not until 5-6k rpm.
So tonight when I get back, I removed the new second valve (peak boost valve) and replaced it with my old bleed.
Problem solved.
I'm going to investigate another valve that I'm sourcing and try it on my car first.
I hope you all appreciate this!!
BASS OUT
I think it's probably not worth the extra cash. the system works well with the one way valve ensuring that the line to the wastegate loses any contained boost pressure as soon as you take your foot off. If you'r finding that boost builds too slowly it's possible that the wastegate is starting to open too soon. This is controlled by the other valve.
I found that the system is sensitive to it's ambient temp. In the Audi it sits against the firewall on the cool side of the motor ( The origional car lives on the Gold Coast) The usual mount point in the Skyline is in a place that can get hot. Thats why I moved it inside the airbox
The reason I finally removed it was I couldn't keep the same boost in all gears, eg 1.2Bar in 1 and 2, 1.4Bar in 3 and up to 1.7 bar in 4th + an E-Boost came up at a good price.
I never had a problem with slow boost buildup or falling off. I was on full boost by 3100rpm in any gear and at least 60%boost by 2700 rpm. It is a good system....but you need to really understand how it works and be prepared to fiddle to get it spot on.
After fitting the old Bleed valve, I now have the impression of the steering wheel on my forehead, as boost cut happened heaps last night.
Can't get it right.
I did have a little restrictor in the system before the first valve as one was fitted in front of the old bleed valve.
I have now pulled that out, but not had a chance yet to go for a drive.
I have to go out this morning at some stage so I'll have another play and let you know.
Can anyone explain this to me like im 7yrs old?
As I understand it a boost controller lets pressure out so the wastegate diaphram doesn't open and allows the turbz to deliver a higher pressure of boost . i.e. "boosted" car.
This looks like it has 2 valves? I read the autospeed article 3 times and still don't understand the difference.
Could someone explain this to me please?
:headspin:
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
