Hi guys, i have for sale a new and unused magnaflow twin tip muffler 3 inch outlet, twin 3 inch tips. Perfect condition
Was going to fit it to my car but as you can see in the picture the inlet diameter reduces to around 2.5 inches where the piping splits. I was OCD about having 3 inch piping the whole way through so i decided not to fit it. Probably one of the best looking mufflers in my opinion, i test fitted it on my 33gtst and it looked perfect.
Selling for $250 firm. These are $400 new.
Located Melbourne, will post at buyers expense.
0413 103 73220170908_171752.jpg20170908_171154.jpg20170908_171443.jpg20170908_171619.jpg20170908_171555.jpg
https://www.sau.com.au/forums/topic/472054-magnaflow-twin-tip-muffler/
  • 4 weeks later...
  • 5 weeks later...
can  you please run a tape measure or ruler across the end of the tips and tell the width of the tips together, as well as the width of the body of muffler.??
i have a Takeros kit on a stagea and am looking to get rid of the milo tin cannon but need to know measurements so can see if will fit in opening
No problem
Width of tips together = 6 inches
Tip length = 7 inches
Body length = 14 inches
Body width = 8 inches
Body height = 5 inches
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
