Morgan12 Posted September 19, 2017 Share Posted September 19, 2017 R33 GTST Auto Issues Hi there, I am new to the skyline family but I am having some issues as of late. My car is a 1993 Auto R33 GTST Skyline 4 DR Sedan. No real major mods. It has been running fine for approx 6 months and now I am having issues with auto box. Upon starting it revs at 1200-1400 rpm for 10 mins then drops down to 500-600 rpm. When it does this, the gears will not change until I hit higher rpm between 3500-4500 rpm. Does this in cold weather more often. Please any advice would be appreciated Link to comment https://www.sau.com.au/forums/topic/472084-r33-gtst-auto-issues/ Share on other sites More sharing options...
GTSBoy Posted September 19, 2017 Share Posted September 19, 2017 Could be just about anything. A serious contender would be the throttle position sensor. It plays a part in idle behaviour and tranny behaviour. But it could also be something that is only affecting the engine speed (like a failed cold start valve or IAC) or it could be a vacuum leak, or it could be a transmission failure that the TCU is sending a signal to the ECU causing the high idle (and the tranny failure eventually makes it not shift properly when it gets warm). By far your best bet is to loosen the bellhousing bolts from the back of the engine, remove the tailshaft, remove the transmission crossmember and shake the car vigorously over a scrap metal bin. When you hear a loud banging noise, your problems will be mostly better. But if you don't want to do that, I suggest getting a proper workshop grade scantool onto the Consult port and look for codes that might explain it. Some of the possibles I listed above should turn up that way, regardless of whether they originate in the ECU or the TCU. Link to comment https://www.sau.com.au/forums/topic/472084-r33-gtst-auto-issues/#findComment-7850596 Share on other sites More sharing options...
niZmO_Man Posted September 19, 2017 Share Posted September 19, 2017 Changed the transmission oil yet? 1 Link to comment https://www.sau.com.au/forums/topic/472084-r33-gtst-auto-issues/#findComment-7850611 Share on other sites More sharing options...
hardsteppa Posted September 20, 2017 Share Posted September 20, 2017 OP, does sound like could be a tps issue. If you search, there are how-to's about putting r33 auto trans into diagnostics mode; suggest you try this and see if it registers any tps fault. Link to comment https://www.sau.com.au/forums/topic/472084-r33-gtst-auto-issues/#findComment-7850632 Share on other sites More sharing options...
Morgan12 Posted September 21, 2017 Author Share Posted September 21, 2017 I should've mentioned I have changed the TPS and cleaned out the IAC valve extensively twice. Also replaced the coolant temp sensor and had the tranny fluid and filter changed. None of the above have fixed or improved. Tried to do diagnostics mode but unsuccessful due to lack of operator knowledge Link to comment https://www.sau.com.au/forums/topic/472084-r33-gtst-auto-issues/#findComment-7850785 Share on other sites More sharing options...
GTSBoy Posted September 21, 2017 Share Posted September 21, 2017 scan tool Link to comment https://www.sau.com.au/forums/topic/472084-r33-gtst-auto-issues/#findComment-7850816 Share on other sites More sharing options...
