Guest Robo's
Well after getting pulled over by the friendly police officer for a "routine vehicle inspection", i got my letter last night to attend the EPA in Victoria.
So i will disconnect my bleed valve and run a straight hose to the actuator, Hide my SAFC behind the ashtray, and change my cat to a smaller size and stuff some steel wool in it.
I might actually ring them coz this is starting to jack me off, as i have a new job and work in the professional industry, i dont find taking half a day off to present my vehicle to the EPA just because mr policeman thought there might be something wrong with it.
https://www.sau.com.au/forums/topic/47234-epa-here-we-come-again/
keep a log book.
thats what im going to start doing. That way you have some stuff to fall back-on later.
ie, harrasment etc etc.
I get pulled over 2-3 times per week, cant wait till i go to court next for whatever reason and bring out my book of "random checks"
As for the EPA, if the car was legal (yours aint) i could understand your issues.
Police report you echaust and it might have been 2 db under at a check a week earlier.
Maybe some class action or something? I dont see why we should pay to satify Brack's revenue raising
I've tried to keep my engine bay as stock as possible. Even my Catch is painted black, the Intercooler is black.. and if a pig too smart I might throw in a couple Black Eyes for FREE! :(
Seriously, What can you do! Pretty much nothing, unless we organise a protest & block parliment house. Now that would be site and a half.... The city blocked by hoons, modded imports, what the heck even some Commowhores aswell.
EDIT: If truckies can get away with, why not the Hoons.
Mesh
Maybe a group letter to Bin Laden to polish off bracks might be the answer? :)
Seriously, imagine if we organised as many car clubs eg: subaru, nissan, toyato honda, mazda etc etc.. in every state and held the protest all on the same day! Then held another protest 2 weeks later, but each state would do it on a different day! That would equal about 1months worth of media, which would have to impact some law changes. Otherwise we can all just sit hear whinging about the cops, EPA, and ADR crap.
if i get much more fed-up...
this could well come into play i reckon.
the support would be MORE than the tree-huggers...
MORE than the poor victimised mothers association
MORE than the scholl teachers
just think if you could get HALF of the people owning modified carrs in vic there...
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
