After 10 years time has come for my skyline to find a new home.
For sale
1998 ER34 sedan 5 speed with sunroof
*Plazmaman FFP with 62mm plazmaman throttle body
*Spitfire coil packs
*Bosch Motorsport 2000cc injectors
*Turbosmart fuel pressure reg
*Inline fuel filter mounted in boot
*Tomei type b cams
*Exhaust side adjustable cam gear
*Performance springs and retainers
*ARP head studs
*Nitto head gasket
*Precision turbo 6062 gen 2
*4” intake and filter.
*Full 3.5” exhaust turbo back
*Tial 44mm waste Gate / can be plumbed in
*6boost manifold heat wrapped
*Custom baffled catch can
*Custom air box
*Oil cooler and oil filter relocation
*Link G4 plug in ecu
*Flex fuel tune by DVS tuning
*Fenix rad double pass
*Jim berry race clutch
*Tomei extreme 2way lsd
*castor arms adjustable
*Front camber arms adjustable
*Rear camber arms adjustable
*Front seats sparco fixed back
*Drivers side 5 point harness fitted
*Quick release steering wheel.
*Drift button on handbrake
*Front rotors slotted
*Rear rotors slotted and drilled
*Black Drift teks 18x8.5 +28 front 18x9.5 +18 rear
*Battery relocated to the boot
*Mscn surge tank Fitted with 2x 044 pumps feeding a -8 line to rail
*Walbro Feeding surge tank
*External pumps staged and all pumps on own relays
*Afr gauge
*Boost
*Oil temp
*Water temp
*Ethanol %
*High /low boost switch
Current power on e85 is
367 kw on low boost 20psi
407kw on high boost 25psi
Asking price is $25,000 ono
message for contact information or any other details on car, like i said have owned this car for 10 years , second owner in the country. she has been in many different stages over the years and is  A lot of fun on track or the street.
  • Like 3
    • ..this is the current state of that port. I appreciate the info help (and the link to the Earls thing @Duncan). Though going by that it seems like 1/4 then BSP'ing it and using a bush may work. I don't know where I'd be remote mounting the pressure sender... to... exactly. I assume the idea here is that any vibration is taken up by the semiflexible/flexible hose itself instead of it leveraging against the block directly. I want to believe a stronger, steel bush/adapter would work, but I don't know if that is engineeringly sound or just wishful thinking given the stupendous implications of a leak/failure in this spot. What are the real world risks of dissimilar metals here? It's a 6061 Aluminum block, and I'm talking brass or steel or SS adapters/things.
    • And if you have to drill the oil block, then just drill it for 1/4" and tap it BSP and get a 1/8 to 1/4 BSP bush. The Nissan sender will go straight in and the bush will suit the newly tapped hole. And it will be real strong, to boot.
    • No it doesn't. It just needs an ezy-out to pull that broken bit of alloy out of the hole and presto chango - it will be back to being a 1/8" hole tapped NPT. as per @MBS206 recco. That would be for making what you had in alloy, in steel. If you wanted to do just that instead of remote mounting like @Duncan and I have been pushing. A steel fitting would be unbreakable (compared to that tragically skinny little alloy adapter). But remote mounting would almost certainly be 10x better. Small engineering shops abound all over the place. A lathe and 10 minutes of time = 2x six packs.
