Hey guys bit of a newbie here but i guess we all started somewhere, anyway in the next month i am hopefull to purchase my first skyline, as i live in wagga wagga there isnt much choice down here so i was wondering what u guys recomend as the best way to purchase meaning, will cause me the least amount of hassle and still be able to get a good deal, either private buy, dealership, or importing, i am willing to travel to look at cars and to pick up after purchase but as i am working 2 casual jobs atm i would prefer not to do this too often, if it help iam looking to purchace a r32 gtst or a type m.
Thanks in advance guys any opinions or suggestions would be helpful.
https://www.sau.com.au/forums/topic/47287-buying-a-skyline-from-the-country/
what's your budget, depending on that you can go thru an import agent, or if you can spare the extra dosh and want some peace of mind, go to a dealer or make a private buy from Sydney.
A LOT of people are beginning to offload their R32's I've noticed due to their concerns over the 15 yr R32's flooding the market. Changes are coming in August that should see an end to that :( So now's the perfect time to buy as everyone's underpricing everything.
prob at the moment anything from 17k down, that would mean i could get its as soon as possible, obviously if i can get something cheaper say a cheap stock example, i would be happy then i could spend some money on some mods.
So u reckon buy private from melbourne,what would be the best way to do this just grab a melb. paper like the herald and look through the classifieds and search this site or would there be a quicker way?? thanks again for your help sorry if the answers seem obvious
firesports.com.au and this site would have the cheapest skylines on it coz people know we know how much their car is worth and won't put bs prices on here.
    • Power steering is probably because someone has nuked the HICAS CU and you no longer have the variable power asist doing what it is supposed to. How much boost are you running? You are aware that any more than 10 psi on the stock ECU is just asking for it to go to full R&R (that's Rich & Retard, which is effectively Retarded and Retarded!) which kills all the power. Depending on the exact conditions, it can just be runnign on the fat and stupid end of the maps, then the conditions change, you make a little more boost and the ECU goes into panic.
    • @BuiltNotBought Just as GTSboy said.   If you want driveabilty and more low down torque..keep the stock runners. They are VERY good from a factory. I have them too on my RB25DET NEO and as a GTSboy i have fmic but with stock piping route(i have Blitz intercooler) Iam making around 320 BHP and the car pulls "hard" from like 2,5k all the way to 7k. I have it dyno tuned to mimic N/A power curve and making little less max torque due to the smallbox tranny. But driveability is very great. I had 350Nm below 3k so car feels very quick.   EDIT:  Not my channel but i saw this and i know that is what i want (and i have exactly this)
    • Looking to sort out a couple of issues on my skyline  It recently was rebuilt, however rebuilder long story short did not give two flying effs about the work he did. So moving forward it's running but I have two persistent issues 1) it has a misfire / lag type of issue (was at higher RPMs but I had a dead piggy back ecu removed which improved it) now it's not as bad but still does it at random, I thought it may have been a boost issue I'm running an older turbosmart dual stage controller, turbosmart told me to try running off gate pressure however it still has a lag at random times. It has New MAF, maf plug, coil packs, sparks, CP harness.. injectors tested and cleaned. Factory ECU. 2) Power steering issue. It is tight as anything. Flushed power steering, rebuilt my pump because the bearing was shot. Flushed again still tight (mainly when parking and going slow into my driveway etc)  No kinks in hard lines, replaced the lines I could see had cracks. Still tough to steer.  I was told to shim a coin and place into the solenoid plug? Is there anything else. My steering angle sensor also has a issue. It's a used one I replaced, does it need to be calibrated? I feel like I've tried everything and this car is my voodoo doll.
    • Holy shit... wow!!! I totally missed this
    • One main filter. Each tank has a prefilter to keep rocks and small children out, then the big main filter that also does water separation. Clogged the first one so bad it was like a rev limiter at 3200rpm. Literally just like dropping the throttle off and maintaining rpm!
