What actually went on the turbo? Bearings or the ceramic exhaust wheel?
Best bet is to get it on a Dyno to make sure there is zero detonation and the af's are ok all the way through the rev range.
Run decent fuel (98RON) not just normal premium.
Detonation will kill turbo's just as easily as it will kill ring lands.
GT30's and GT35's generally are around $1900.
Be carefull to ensure the GT30 500hp really is what it is supposed to be.
  • Replies 86
um i got some tests done and they said that it was just the selas in the turbo that are blown everything else is good..
No FMIC?
Get that first. Buy a kit and fiddle around fitting it. Learn about your car. :D
Its rewarding. :rofl:
Then when you do get the PowerFC it will make ~190rwkw, if you can drive you will pull you a mid to low 13sec 1/4. Some have even ran 12.9's.
Thats pretty quick when you consider you don't have 4wd to help you off the line :D
nope street tyres...235's at that....
but thats a v8 with a 3 speed tricked out auto behind it
full street trim street registered VN SS comodore with a 308 in it...
i hate hime 4 it
nah he ran it 3 weeks ago at willowbank at the street meet....an yeah LOTS of wheel spin....its the only car i have ever been in were u kan be doing 70km an put da foot flat and it still smokes them...lol very scary
if ne1 was there it was the gunmetal grey with a pink pearl VN... laid a quarter track burnout b4 the run...lol show off
yeah it sounds absolutly AWSOME....twin 3" exaust fuel injected 308 stroked to 350...MASSIVE cams...87k spent on the motor all up...an the cheeky bugger got
it 4 18,000 cause they guy was going bust....made me very mad..
but yeah i wanted good fuel economy aswell an i jus luv the look of a skyline...
thats y i choose mine instead of sum tough V8
ohh yeah ill tell be honest..i got offered a 500Hp garrett turbo that need an external wastegate for $400 brand spanking new neva been used an still in the box.. just want 2 see if i kan afford 2 do the whole setup properly...thats y i just need 2 know but modding the manifold or gettin a second hand stainless steel one 2 suit...
Don't buy stolen parts. It makes you no better than the thief. Plus you will have no right to whinge if your car ever gets stolen.
yeah well i know how 2 drive decent enough...
:bahaha: He says with all the years behind him......:bahaha:
Don't buy stolen parts. It makes you no better than the thief. Plus you will have no right to winge if your car ever gets stolen
DAMN STRAIGHT ! 1 thing i cant stand is people bragging how they can get "Cheap" gear but their always the F ucken loosers who complain like a bit ch when their shit gets taken....
i didnt say it was stollen.....
they might be but i dont know..all i do know is they are cheap.... and brand new..an supposedly only being sold because the guy cant afford 2 do the mods nemore.....
probly bull crap but neway
Bl4cK32: i didnt say i kan drive good i just said that i kan drive decent....(i live on a farm an drive trucks tractors cars bikes....EVERYTHING an have been 4 about 7 years now)
I know you didn't say it was stolen, but bollocks if it's not. Hang on, "they" are cheap? He has a case full of them? If you are still naive enough to seriously believe they aren't stolen then you're, well, naive.
    • perhaps i should have mentioned, I plugged the unit in before i handed over to the electronics repair shop to see what damaged had been caused and the unit worked (ac controls, rear demister etc) bar the lights behind the lcd. i would assume that the diode was only to control lighting and didnt harm anything else i got the unit back from the electronics repair shop and all is well (to a point). The lights are back on and ac controls are working. im still paranoid as i beleive the repairer just put in any zener diode he could find and admitted asking chatgpt if its compatible   i do however have another issue... sometimes when i turn the ignition on, the climate control unit now goes through a diagnostics procedure which normally occurs when you disconnect and reconnect but this may be due to the below   to top everything off, and feel free to shoot me as im just about to do it myself anyway, while i was checking the newly repaired board by plugging in the climate control unit bare without the housing, i believe i may have shorted it on the headunit surround. Climate control unit still works but now the keyless entry doesnt work along with the dome light not turning on when you open the door. to add to this tricky situation, when you start the car and remove the key ( i have a turbo timer so car remains on) the keyless entry works. the dome light also works when you switch to the on position. fuses were checked and all ok ive deduced that the short somehow has messed with the smart entry control module as that is what controls the keyless entry and dome light on door opening   you guys wouldnt happen to have any experience with that topic lmao... im only laughing as its all i can do right now my self diagnosed adhd always gets me in a situation as i have no patience and want to get everything done in shortest amount of time as possible often ignoring crucial steps such as disconnecting battery when stuffing around with electronics or even placing a simple rag over the metallic headunit surround when placing a live pcb board on top of it   FML
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
    • I think Fitmit had some, have a look on there (theyre Australian as well)
    • Hah, fair enough! But if you learn with this one you can drive any other OEM manual. No modern luxury features like auto rev-matching or hillstart assist to give you a false sense of confidence. And a heavy car with not that much torque so it stalls easily.
