Still a few spots available for a blast around Winton next weekend in the crisp Autumn air, perfect for PBs!
You don't need to be a club member, but you will need a valid CAMS/AASA and a car that will pass scrutinizing.
Cars are split by class, prizes awarded for class winners, and there's plenty of track time for everyone. there's even a top 10 shoot out at the end of the day for the 10 fastest cars.
Official timing is included in the cost, only $150 for the day!
I might be a biased, as this is my local club, but it's a great bunch of drivers, a good range of cars, and always an awesome day out.
I'll see you there :D
Sign up: http://www.awdcc.com.au/?p=2134
Facebook group: https://www.facebook.com/groups/awdcc/
Edited by ActionDan
Hey Dan, im interested in coming along. Was just reading the supp regs and reg 42 says.
  -All laps will be in an clockwise direction of the 2000m circuit
Was wondering if the event will be run on the full or short course as 2000m sounds like the short?.
Cheers Bill
[mention=139042]admS15[/mention] Good work yesterday, you came second in class.
Thanks Dan, i actually ran a 1.37.75 which may have made me first on my last lap of the day but it didn't count as the red light for end of session came on as i came out of the last corner. I knew i was on for a good time, race chrono was showing me greens, so i kept going. Robbed unfortunately but I'll count it as a pb for me.
Overall, event was run quite well, good turn out, nice bunch of blokes and some damn quick cars. Wouldn't hesitate to enter another one of your clubs events.
Not bad for a CA powered S13 and a street regd R33 on Nankangs. We probably could have both been a second quicker if the nankangs where brand new.
Was happy to run that time and still be able to make the 3 hour trip back home.
Was nice to meet you too and finally put a face to the name[emoji106]
  • Like 1
    • I'm going to slap an old nismo logo sticker on my spare one and sell it to the land of the free for a thousand bucks
    • lol, probably should have read further!
    • Well - they have arrived.  And they are easy on the eye to put it mildly... These only have three bolts - but for a start there is a key that fits with vacuum like precision..  And as you can see by my ruler, the interface is large..   I listened to a podcast on HP Academy about Dan (KiwiCNC) and I'm more than comfortable he knows what he is doing. R35 Bearing assembly should arrive later today so can mock that up for a look. Can't wait to get these on and get some brake pressure logging too. IMG_3860.MP4
    • I would be very confident that they are the same parts (the 2 different SKUs). It seems very clear that you can drop the cam in the 2-way opening, or in the other opening. If you arrange it in the other opening in the same way that you see any other 1-way diff, ie, with the flat of the cam up against the 1° side of the opening, then it would work as a 1-way. It can only spread the ramps when driving forwards - cannot spread the ramps on overrun. It would then appear obvious that if you put the cam into the opening "backwards", that you would get the angled flats of the cam working onto the "points" of the 1° side of the opening, which would give you ramp spread in both loading directions. I do wonder if the forward direction of the 1.5-way config is equivalent to the forward direction of the 2-way, seeing as the cams are flipped and the angled surfaces on those would need to be the same on each side - AND - clearly when installed in either the 2-way or 1-1ay configuration they are not intended to work exactly the same (the ramp angles on the 2-way are 10° different between forward and backward, and the ramp doesn't exist in the 1-way config). 'twere me, I think I would rather actually have a set of rings that offered the 2-way with two different sets of ramp angles, say the 55/45 of the existing design and maybe a 45/37.5 combo for a less aggressive effect), AND another set of rings with a dedicated 1.5-way opening and a dedicated 1-way opening. The 1.5-way opening would actually have the steeper angle on the overdrive side that causes it to be less pushy than the forward drive angle, like you see in many other diffs. But really - if this Nismo thing is thought out properly and all those surfaces work on each other the way that they need to, who am I to argue?
