Doing a bit of a clean out so have a few things sell on.
KTS 6 point FIA Harness - $70
Got it from KTS when I was living in Japan (was my local tuning shop)and have used it maybe a dozen times. Good quality product, but do note that the FIA part of it ran out at the start of 2015 and its manufacture predates the FIA hologram which came into effect from 2013.
Here's the link to them on the KTS website, https://www.kts-web.com/product/interior/bb_013.html
2x KTS rear coilovers ECR33 Skyline GTS-T  - $99
Have been sitting collecting dust so need to go. Springs were changed from 7 to 5kg to make it better suited to Aussi roads and lower mounts were changed to polyurethane
How to Digitally Photograph Cars (book) - $35 incl postage
Great book for anyone into shooting cars with digital SLR cameras. Lots of tips, tricks and examples. I used this back when I was freelancing for HPI magazine and it was a great tool for improving my photography skills. New ones on ebay are still going for $70 - $130, so its clearly still in demand
Moretti Portable Aircon unit 5kw - $150
Ok, apologies its not car related, but I have no use for it as this house has ducted AC. Bought it approx. 3 years ago and works like new. Snap up a bargain and be ready when summer comes back
Located in Melbourne outer eastern suburbs
https://www.sau.com.au/forums/topic/474049-couple-of-parts-need-to-go/
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
