Hi,
So I picked up my puretron a couple of weeks ago and have had a look and there doesn’t  appear to be any indication of positive and negative on the power cables for it  just a black and a grey cable.
My better judgement would say black is positive but I’d like to be sure as I don’t want to pop the electronics inside it when I wire it in.
I’ve had it apart but can’t make out which is positive and negative as they are on a small connector that connects to the blind side of he pcb.
If somebody knows this one it would be much appreciated.
Thanks
Paul
https://www.sau.com.au/forums/topic/474093-puretron-polarity/
Thanks guys, the thing that threw me was looking at the lambda sensor apparently the black is the signal and cream is the ground.
As tridentt150v says black is used as the nuetral in all other things.
I'll give it a try when i get home, Richmond98 thanks for the shout on that hopefully mine will do the same.
Cheers
Paul ?
    • So either way it is gearbox out and look what is wrong?  I know about the input shaft bearing. Even before swap/new clutch the it sounded exactly like this: So is that inout shaft bearing or the other was installed backwards?  And can some please tell me the part number for that input shaft bearing? The gearbox is small box from R34 N/A and number is FS5W71C. Thank you
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
    • D2 and Ksport are essentially the same thing and basically just generic Taiwanese manufacture. Better than ChinaBay crap, but... not top shelf. Öhlins have got to be some of the best dampers around, so likely to be a good option. It's going to get to the point though where I suggest you buy from Oz. We have at least 2x excellent options here. If I were you though, I'd be talking to KW about doing something for the R33. There's bugger all difference between that and the 32. In GTR land, anyway.
    • KW only offers a set for the R32 GTR. Popular options are D2 racing, Ksport or Öhlins. I have a D2 Racing coilover set, though I don't know for sure which one.
    • Well, the good news is you have more than one very good option for new coilovers in and around your country. Worth the drive over to KW to talk about GTR stuff.
