Mine is stuck open and passenger side still goes up and down. Found this on how to fix.
http://www.rbmotoring.com/blog/nissan-skyline-r32-window-wont-roll-updown-fix-diyhow-to-guide
my question is what did he actually do with the soldering. Did he just place some solder over the end in the picture or what.
Basically you are refreshing a "dry" joint. The solder on the board is no longer connecting the wire to the board. You will need flux to help the solder to flow.
Edited by Rusty Nuts
  • Thanks 1
I do have a solder gun to work with. Might do this tomorrow morning.
Have you tested the window motor. Apply 12v to the terminals and confirm it will move up and down first. The brushes in the motors are not replaceable. I am using Patrol motors in mine.
Yea they said another test is to see the passenger side window still works. Which it does.
Actually this only tells you there is 12v available in the system. It doesnt mean the motor physically works buddy.
Oddly enough after leaving the in laws to go home the damn window rolled up. I’m still gonna re solder whatever is giving it the fits
Test the actual motor, that's what mine was doing before the thing gave up completely. Try the simple things first!
  • Thanks 1
4 hours ago, SeanR32GtSt said:
How’d you set yours up to test
Mine had bullet type connectors which were not original, so i plugged male connectors on with short length of wire attached and used jumper leads from the battery. If your battery is in boot use someone elses car battery. You could also use a battery out of a 12v power tool.
I’m gonna tackle it today after I get done stripping the stain off my front porch. I’ve used the car couple times since and of course the windows worked fine but it still needs addressing in case I use it to drive into downtown and can’t roll it up when I park it.
  • Haha 1
Wise to fix it, when mine was working occasionally, It was broken into, the dog who got in stole the small change(master criminal) and smashed the ignition lock, destroyed surround, etc. I have the number of the car he arrived in, didn't call cops, just tracking him down and will deal with him old west frontier style.
    • Hi from Canada, Both of my calipers are starting to fail. My car is a 2005 M35 Stagea ARX and I can't seem to find any parts or any cross reference caliper that would fit my car. Is there a company or a similar caliper that would fit and I could replace the OEM one. Or if anyone knows where I can find a new OEM. Any help is very appreciated. Let me know!
    • Maf is a question mark but TPS  I have set at 0.47, the fact that I’m getting proper voltage range out of it with the key on leads me to believe it’s functioning properly. I’m getting proper voltages on basically everything. I still need to look up voltage ranges for z32 maf and test that
    • Honestly no not at all, but it’s a very basic tune, it’s stock injectors q45 tps and z32 maf. Other than that it’s a completely stock base map. The file is from nistune and from my understanding if it was tune related I would be able to unplug maf and tps and it would still start even if it was a really shitty start. I have tried starting it with coolant temp, maf, and tps unplugged none of those 3 togethor or individually changes anything
    • 🏆 Skyline Supremacy Meets Mount Panorama Magic 🏆 Join SAU NSW as we take the long way to Bathurst, the home of GTR greatness. Saturday 30th August 2025 7:00AM Meeting Hanna Park North Richmond 7:30AM Departure Cruise Via Bells of Line Road 9:00AM Arrival to Stop 1: Golden Poplars Meadow Flat 9:45AM Arrival to Final Destination: Mount Panorama Motor Racing Circuit Meet Location: Hanna Park North Richmond Stop 1: Golden Poplars Meadow Flat Final Destination: Mount Panorama Motor Racing Circuit   *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • What does it look like with highway driving? And yes, I had a similar thought as Duncan. It looks quite similar in my Stagea and I have made myself accept it as normal. Might have to look into it some day   Highway gets as low as 10l/100km on my end so I'm not as worried about it being a mechanical issue. More likely just the tune on the haltech.
