Mine is stuck open and passenger side still goes up and down. Found this on how to fix.
http://www.rbmotoring.com/blog/nissan-skyline-r32-window-wont-roll-updown-fix-diyhow-to-guide
my question is what did he actually do with the soldering. Did he just place some solder over the end in the picture or what.
Basically you are refreshing a "dry" joint. The solder on the board is no longer connecting the wire to the board. You will need flux to help the solder to flow.
Edited by Rusty Nuts
  • Thanks 1
I do have a solder gun to work with. Might do this tomorrow morning.
Have you tested the window motor. Apply 12v to the terminals and confirm it will move up and down first. The brushes in the motors are not replaceable. I am using Patrol motors in mine.
Yea they said another test is to see the passenger side window still works. Which it does.
Actually this only tells you there is 12v available in the system. It doesnt mean the motor physically works buddy.
Oddly enough after leaving the in laws to go home the damn window rolled up. I’m still gonna re solder whatever is giving it the fits
Test the actual motor, that's what mine was doing before the thing gave up completely. Try the simple things first!
  • Thanks 1
4 hours ago, SeanR32GtSt said:
How’d you set yours up to test
Mine had bullet type connectors which were not original, so i plugged male connectors on with short length of wire attached and used jumper leads from the battery. If your battery is in boot use someone elses car battery. You could also use a battery out of a 12v power tool.
I’m gonna tackle it today after I get done stripping the stain off my front porch. I’ve used the car couple times since and of course the windows worked fine but it still needs addressing in case I use it to drive into downtown and can’t roll it up when I park it.
  • Haha 1
Wise to fix it, when mine was working occasionally, It was broken into, the dog who got in stole the small change(master criminal) and smashed the ignition lock, destroyed surround, etc. I have the number of the car he arrived in, didn't call cops, just tracking him down and will deal with him old west frontier style.
    • Crazy how good the aero bar looks compared to the stock one
    • Yes, but you will need to rewire all the things that are different. CAS, coils, etc. Yes, but there is no IAT. What? You can use anything you like. It just has to be hooked up so that it will work.     Or are you wanting to just plug and play without having to do any thinking/work?
    • It's been a little over a decade since I bought the S15. As I did on my socials, I'll share some of my favorite pictures from over the years further below. If you haven't realised, pretty much all the pictures in my posts are ones I've taken.  In terms of updates, I don't have pictures, but I acquired a near-perfect pair of fog lights from a friend of mine, so those got swapped in for the pair I already had. As for the JZX110, I just got it back from being fixed. A few weeks back, I was on the highway when I suddenly drove over something with very little time to react. It was probably the size of a soccer ball, but it went under the car and banged into the underside pretty loudly. I pulled over and realized the fluid leaking was fuel, and of course, it was right near my exhaust. This required replacing the fuel tank. If you happen to be in the same predicament, thankfully this car shares a fuel tank with the JZS171, IS200, and IS300, so it wasn't too painful to replace. Enjoy some pictures as mentioned above, including the carnage from the fuel tank and a bonus picture I came across which shows how ridiculously shiny the Bugels are on the 110. So many more pictures I could share of the S15 but this will do for today, enjoy.
    • Welcome.  Was the mistake the car, or joining us? 😏
    • Yeap, was me and the daughter getting coffee before heading to the new joint to measure up the fridge space and taking some pics that the solar installer wanted of the switch board
