1. Fresh built short block RB30 stroker 3.4L 94mm spool crank, Spool I beam rods, Custom CP pistons 87mm (40 thou over) all parts now still have boxes block currently at Abbotts Engineering Gold Coast. $6000
2. Haltech platinum pro r33 rb25 $1250
3. ID Injectors with fuel rail and Sard FPR and fuel pressure gauge. $800
4. 3 x Bosch 044 fuel pumps 2 new 1 used $150 new and $100 used
5. 2 x Walbro in tank fuel pumps 1 new and 1 used. $100 new and $80 used
6. 70L aluminium drop tank fuel cell $150
7. Custom made aluminum radiator shroud with 2 x thermo fans + aluminum radiator $400
8. R33 ARE oil cooler fits between headlights with steel braided hoses. $500
9. Massive intercooler new in box $300 can get size upon request
10. Garrett GT3582R used 1000kms max $1000
11. Garrett massive truck turbo unknown specs can get specs upon request.
12. Top mount exhaust manifold with 38mm external wastegate and screamer pipe. $250
13. HKS Super dragger high flowed $250
14. HKS oil filter with relocator kit $200
15. HKS BOV SSQV $75
16. Huge yellow top Optima 990 CCA dry cell battery $225
17. Eboost2 with wiring and mount near new condition $450
18. Autometer carbon fiber gauges ( air-fuel ratio, water temp, oil temp, boost and fuel pressure) $75 each or $300 for the lot.
HEAPS MORE PARTS INCLUDING SHELL, INTERIOR, AFTERMARKET AND OEM. HEAPS OF CARBON FIBRE PARTS.
CALL OR MSG ME FOR DETAILS AND PICTURES. LOCATED GOLD COAST, QLD
0423016792
20180704_111601.jpg20180704_111639.jpg20180704_111856.jpg20180704_112432.jpg20180704_112425.jpg20180704_112026.jpgIMG_1242.JPGIMG_1243.JPGIMG_1248.JPGIMG_1249.JPG
  • 1 year later...
Hi mate
how much for the carbon fibre gearstick cover with ash tray(don’t know what to call the piece)
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
    • Thanks for the quick reply. To be clear, when you say turbo shuffle do you mean turbo flutter "stustustu" or referring to something else? I had thought they were the same thing. When I wrote the post my intention was to say it wasn't a flutter/compression surge sound. My understanding was that a flutter sound would be occurring when throttle is released, whereas I can keep the throttle in the same position for this noise
    • Hi everyone, I've been wrestling with this for a while now and have been trying to find out the cause. For context, the turbos used are Garrett 2860 -5s, the BOV is a BNR32 HKS SSQV IV kit, the car is currently tuned to ~470 whp on 17.5 psi. The car drives normally, pulls well when it doesn't happen, and I can replicate it fairly easily. It does not sound like turbo shuffle or flutter. The engine has only a thousand or so miles and has had this behavior since it was completed. After my engine was built for my R32 GTR, I noticed that the car now sometimes makes an air discharge sound on what appears to be positive boost pressure that sounds really similar to a BOV. I had thought that it was a BOV issue but even when replacing it with a brand new unit, the sound persisted. It seems like it's coming from the passenger side but I may be mistaken. The closest scenario I could find was this post here https://www.gtr.co.uk/threads/maybe-a-boost-leak-opinions.147955/https://www.gtr.co.uk/threads/maybe-a-boost-leak-opinions.147955/ started by @yakshii and it sounds very similar. As in, at partial throttle once I reach positive boost I begin to hear the same psh psh psh psh psh sound like air is leaking somewhere when I keep the throttle in the same position. It most commonly happens in 4th gear at around 3-3.5k RPM and 5th gear around 2.5-3k RPM, which seems to coincide with normal positive boost thresholds. It might be similar to what @Austrian GTR mentioned about his own HKS SSQV. Notable difference would be that when he applies more throttle when it happens, it stops. In my scenario if I apply more throttle during this repeated psh psh psh sound, the cadence of the sound gets faster and louder rather than stopping. If I lift off slightly and apply throttle again, it will normally stop and pull without issue. I've checked all rubber couplers to ensure that they are tight, but have not gotten the opportunity to properly do a pressurized boost leak test. If anyone has had similar experiences or thoughts on what might be the cause, I'd be very keen to hear them. I also have a video of it happening from inside the cabin, if that would make it easier to understand: https://youtu.be/2zqZXcx8jbA
