Hello all I have a 1992 rb25det swapped gtst.
So the run down. Car idles at about 1k but its consistent.
Has a power fc. Full 3inch back . Intake and that is all as far as mods go.
Car pulls -20 in vac
And hits full 7psi boost.
However car feels slow as dirt and at about 5k rpms to 6k it'll sputter really bad and not want to go anywhere. But if you only hold it to about 2 psi till 6k from 6 to 7.5 k it'll feel like a rocket and like its suppose to be.
Things I've done.
Checked for boost leaks. I found 2 small ones and fixed those.
Changed plugs however I haven't re gapped them from the .8 they come in.
Changed and liquid taped coil packs.
Car runs extremely rich like 9 when full boost.
Afm doesn't have any sticker or anything on it for me to know which one it is.
Any info as to what else I can do to get this car running good would help and thank you.
https://www.sau.com.au/forums/topic/474666-the-rb25det-sputter-at-5k/
9 AFR on boost is uh, plenty rich. But how do you know it's running 9:1?
If you have the means to accurately determine that... and a powerFC you should be able to lean it out to a far more reasonable AFR. That said, that will be the first thing the tuner does. I would consider having a spare set of plugs handy if the car is driving around on 98 with a 9:1 AFR because they will foul up pretty quickly and you'd hate to be caught out on the Dyno like that.
The reason I ask is it'd be strange to have a wideband, and a modifyable ecu, and have a 9:1 AFR on full boost unless as mentioned a bit above, still running stock map.
But even then the base map wouldn't be that far out unless something is decidedly not stock anymore, like injectors, or the AFM isn't what the powerFC thinks it is.
The answer really is tune it. If not comfortable and it's getting a tune anyway, drive it to the tuner very conservatively and have the spark plugs ready to go when it's going on the dyno ?
Any issues (if any!) will become more apparent once the AFR is under control.
Yea I thought it was very strange as well. I had bought the car with the swap and pfc and was trying to figure out why it smelled like gas and what not so I installed a wideband to see.
I honestly dont think that afm is the stock one which is what it believes is on there.
So after looking at my maf and various other ones I believe mine is the z32 maf which would make what you said @Kinkstaah correct. Will be taking it for a tune this week with an extra set of plugs lol.
Side note there is no label or anything on my maf so I'm just going by looks comparison
    • I know people cry at the price of the Getrag 12-14k for a conversion now, but it really is a nice mid point. Not going to get change from 10k on a gearset installed.  $30k++ for sequential.   I know you run the risk of a damaged used one and parts are hard to get but as a street car gearbox its really hard to beat. If you enjoy a more traditional manual, its the choice no question.
    • Time to decide what’s more import, your power level or your budget because you’re going to struggle to keep both
    • Our Southern Highlands Cruise is proudly registered with “R U OK?” Day.  Sometimes the best way to check in on your mates is by getting out for a drive together. Sharing a common passion like cars creates the perfect space to chat, connect, and support each other.  A simple “R U OK?” can make all the difference. Let's enjoy the drive, the company, and look out for one another. PLEASE WEAR YELLOW FOR “R U OK?” DAY Sunday 14th September 2025 9:30AM Meeting Crossroads Homemaker Centre 10:00AM Cruise Departure Via Old Hume Hwy 11:45AM Arrival at Mittagong RSL Club Meet Location: Crossroads Homemaker Centre Final Destination: Mittagong RSL Club *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • Yep, its been down for a while, as I understand it it will be back soon.
    • Yeah I also looked at Plazmaman, but, it ended up alot  cheaper getting black ones through EFI when you also added in the delivery cost
