Guest twotone33
NISSAN SKYLINE R33 GTST 1994 $19500 ono or swap for car and at least 13 grand so i can pay this stupid debt and survive when i move into new house.
2.5 LTR TURBO 6 CYLINDER
ALWAYS GARAGED AND ALWAYS SERVICED, BOUGHT FROM ACTUAL COMPLIANCER WHO HAD CHOICE OF THOUSANDS OF SKYLINES AND CHOSE THIS ONE, THEN SOLD IT 2 YEARS LATER DUE TO MARRIAGE.
5 SPD MANUAL
HEAVY DUTY CLUTCH
**RARE**FACTORY 2 WAY SUNROOF
GFB BLOW OFF VALVE
3" MANDREL EXHAUST WITH BLITZ NUR SPEC MUFFLER
TURBO TIMER
POD FILTER
CUSTOMISED INTERIOR
STRUT BRACE
100000KM SERVICE DONE AT 85000KMS INC TIMING BELT
95% BLACKOUT WINDOWS
TOP OF THE RANGE REMOTE START ALARM SYSTEM
17 X 10 LIGHTWEIGHT WHEELS - TALK BOUT GRIP!!!!!!
TRUST FRONT BAR (SUPERLOW!!)
CURRENTLY RUNNING 13PSI (MECHANICALLY APPROVED) WITH PREMIUM UNLEADED.
HAVE BEEN TOLD IT HAS 2 GRAND WORTH OF SUSPENSION BUT AS I KNOW NOTHING ABOUT SUSPENSION IM NOT SURE, HANDLES LIKE A REAL DREAM THOUGH!! STICKS LIKE A SLOT CAR.
CAR IS IN EXCELLENT CONDITION THROUGHOUT. ANY TEST WELCOME!! LOOKS TOUGH AND SOUNDS AWESOME. REAL HEAD TURNER. HAVE PUT G-TECH ON IT AND IT RUNS 0-100KMH IN 4.8 SEC. EXTREMELY REGRETFUL SALE, SELLING DUE TO HOUSE PURCHASE. TEST DRIVES CAN BE ARRANGED BUT LIMITED DUE TO INSURANCE REASONS.
WILL CONSIDER CASH AND SWAP FOR CHEAPER MANUAL TURBO CAR.
FEEL FREE TO CONTACT ME AT [email protected] FOR ANY FURTHER QUESTIONS.
https://www.sau.com.au/forums/topic/47525-fs-or-trade-r33-gtst-near-melbourne/
    • Sounds more like what Brad said, that it's mainly transfer. What pad bed in procedure did you use, and did you replace/machine the rotors, or just swap pads?
    • The stutter is almost entirely in the pedal. I don't feel the brakes release and reapply as you would with ABS engaging but the pedal feels that way, without the brakes releasing. It only lasts for less than a second and the pedal is fine again. It's hard to explain, sorry.  I'll get under this weekend and just double check everything is tight. Fluid is at max where I left it.
    • What bedding in procedure did you use?   When you say stutter, what exactly do you mean? Like it feels like someone letting go of the brakes momentarily and regrabbing them again to get you to stop? Re-reading your post, and that is what it kind of makes me think you're explaining, like theres a little bit of a jolt, likely just as you're reaching a stop. I've only had this issue once. And if its caused by what caused mine, you will want to get the car up on stands again and check it over. Mine was a case of a caliper mounting bolt coming out and letting the caliper rotate on the other remaining bolt and gave play in a wheel as it came to a stop. But not every stop either!
    • Yeop... binned it   This will be a summary will not many pics atm and cbf  Fixed the samsonas - it was totally munched Put a new precision 7675 T4 on with proper split pulse mani Got to Sydney to get to car - drove to canberra to get racecar - drive back to sydney that night Next day all day at Plasmaman putting on new clamps cleaning some things up and adding another large engine oil cooler sitting at the rear above diffuser to keep things cooler Next day - Tuesday - on Dyno - killer wikid awesome pumped out really good numbers - more mid range and on lower boost levels Wednesday - first prac - all day again getting the suspension right - had to borrow front suspension again - out do a lap come in - out do a lap - in - what i had just couldnt handle the load at the more consistent higher speeds - got a lap in at the end of the day that was pretty reasonable  Put it this way that lap wouldve had me in 4th in Pro am for the whole event - with only 700 hp and used tyres Thurs first official prac day - lap out warm up - then entered a hotlap with above setting and 80% effort took corners 1,2,3 and into 4 car felt awesome -  rear came around out of nowhere bang into the wall near front on at whatever 140 kmph Done, over, gone Just one of those how did that happen apparently as all indications show nothing out of the ordinary Got to spend the rest of the time at the event like I hadnt done before - was actually Ok mainly as I had my family and my boy is 9 and got treated like a rockstar Long trip home, lost a trailer wheel in nowhere land, X5 airbag suspension gave up half way across nullabour and rode on bumps stops (its now completely fine) had to do a 19 hr drive day on day 3 as accommodation got screwed up so just had to keep driving till found a town with some Now to reassess - hopefully the motor and other things are OK but yet to be seen too. There is no easy fix there is no i'll just order that part and get it sent - we'll have a talk to people see what can happen and what the go is but at minimum its rebuild from scratch struts forward and alot of time effort and $ should and if I return and if but maybe/ when  I have the cage tied into the front strut towers - if I didnt have that things couldnt been worse you can say its just a front end but if you know what goes into these cars... you'll know what that actually means in reality   Car was very fast. Disappointing we just didnt get to show it Effort doesnt win you races though     Apparently this is motorsport !
    • Thanks, will do that.  Thankfully they still feel great.
