who gives a crap about diet... i know i dont
im just going to walk the dog everyday like a madman
see what happens
will still be drinking and eating bad
will go for a run every now and again
so here goes
hopefully i wont get bored of walking and even might find my rugby boots and play again
FATZ
data weight comments
30/7/04 128kg of love... come and get me ladies (gut, man boobs, fat arse)
https://www.sau.com.au/forums/topic/47543-the-thinning-of-fatz/
  • Replies 73
There are only 4 more games in the season...
31/7/2004 vs Beecroft (Away)
7/8/2004 bye
14/8/2004 vs Forest (Home)
21/8/2004 vs Iggies (Home)
28/8/2004 vs Collegues (Away)
Get your ass down there at the usual time.
Cheers
Mick
Boys, You're just not drinking enough.
Alcohol is a diaretic. So gets rid of excess fluid.
Beer is good. "Steak in a glass" as they say. And factor in all that exercise going to and from the bar/fridge.
Ever seen a fat alcoholic ?
Just stay away from Kebabs. It will only end in tears anyway (and probably vomiting and/or diahorrea).
I'm taking this on the road soon, but no evangelical consultancy fees to you guys in SAU.
Enjoy !!
El Bee
shit i was once buff at 115kg
now 127 im fat
so my target is 115
im 6'5 and pretty wide.
shoule be some fun and b man if you want to hit it im up to my 8th already... got to love friday baby
come over tomorrow for more cans i say!!!!
nath and i are going to take up squash maybe it will help
Pete
Damn you Fatz - I only started my first.
I'm with elbee111 - more beer
more beer, more beer, more beer, more beer, more beer, more beer,
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
