All,
i am installing my walbro fuel pump this weekend. I understand the r34 gtt standard wiring uses a two stage fuel relay so on idle it cuts fuel or supply much less voltage (11v ) than 13.5 v.
my question is, i normally use a joint coupler with heat shrink covers. Is that ok inside a fuel pump? Obviously i will do the connection outsite of the fuel pump and then put it back in to the fuel pump.
i don’t think you can use electrical tape, can you ?
https://www.sau.com.au/forums/topic/475982-r34-walbro-255-fuel-pump/
I'm maybe thinking more along the lines of a small I.D silicone fuel resistant hose (small motor fuel hose) line the exposed wiring/solder joint with something like https://www.supercheapauto.com.au/p/permatex-permatex-fuel-resistant-gasket-sealant-85420/356517.html and slip the silicone fuel resistant hose over it. the gasket sealant is non hardening so should keep even a slightly loose hose in place permanently as the sealant wont harden. Best I can come up with man hope it helps!
Thanks, will check it out
i am pretty worried on what happengs if positive and negative touch inside the fuel tank.
i think answer is spark and then boom. Have fine japaniese engeenering not thought of this?
even if fused, a small spark is enough to blow up the car with 60 liters of gas
re wire, i am thinking of soldering, what do you recon?
There can't be a boom in a sealed file tank even if the wires touch. No oxygen.
When I do pumps I offet the joints, so they can't touch and the use a piece of submersible fuel line over the positive joint. Like heat shrink but not shrunk.  None have exploded, so that's a pretty good result.
4 hours ago, drifter17a said:
If for whatever reason they do, screw coming loose?
lots of diy jumps simply use a wire connector so they could be setting up a death trap
just amazed really on how stupied the design is
Too rich to ignite, even if you arched something inside the tank it won't ignite, even if created a physical spark it still won't ignite.
Engineers aren't stupid :)
that is what I didn't know :)
well I was going mad getting all sort of sleeve to ensure they won't touch ...
5 hours ago, Ben C34 said:
If you don't believe us take off your petrol lid and drop a match in
will do later this evening, use my blow tourch .
i wonder why in the UK there is an old trick of calling the police and asking for a car to be removed which seems to have been abandoned by removing fuel cap and saying it is a fire hazard.
normally when the car is taxed( road tax) and MOT( mechanical check once a year) then they won't remove it but it if it annoying you people do above
Do not do this on a warm day, there will just enough fuel vapours and just enough air to ignite, just as the match goes down into the fuel neck lol
Won’t go boom though.  Do it.
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
    • Literally looks like direct port nitrous haha
