These are direct fit injectors to suit neo motor, no modifications to mount and factory wiring plugs straight on.
They are suitable for use with e85.
I had these in the car for maybe 12 months and 2000kms, no issues at all, only changed out for larger injectors.
Will swap for R34 under engine splash tray or sell $150
Located NSW 256620190213_140529.thumb.jpg.ce7f8df67c974acd2b0c68e8098b9c15.jpg
Edited by NEO25T
Spelling
https://www.sau.com.au/forums/topic/476048-denso-840cc-injectors-to-suit-neo/
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
