Hello all, I'm new to the site but not entirely new to RB's, I've had a customer at my shop who had two r32 GT-R's with rb26dett and a GTS-T with an rb20, we installed a ecumasters EMU on his rb26 with upgraded r34 twins, tuned in on e85 and made me fall in love with the sounds of these engines.
Fast forward to now, I've traded for a 91 240sx with an rb25det swap. I did all the basic maintenance, cleaned up some of the wiring and am now looking to turn it up a bit. My previous customer had left me his original rb26dett ecu, and my s13 had a nistune type 2 board in the glove box when I got it. I also already have an ostrich emulator and burn2 chip programmer from moates.net. I've installed the socket in the ecu, but I would love some input on the best route to proceed. I've got a vci with an adapter for the nissan consult port, but to my knowledge no consult port was added to the vehicle with the swap, while if i am correct I should be able to just plug my ostrich in and load the nistune suite and get to work.
Advice?
https://www.sau.com.au/forums/topic/476241-rb25det-tuning-in-240sx/
I would get a new Nistune board and install a consult port direct onto the ECU connector.
No need to burn chips and use emulators, not to mention you could implement full flex support and hook up a launch control switch as well.
I think it's not super easy to use the RB26 ECU on a 20/25.  Whilst the 20 and 26 ECU are super similar, the fact that the 26 expects to see 2x AFMs and 2x O2 sensors and shit like that makes extra challenges that you don't need.  The effort required to use it would be better spent elsewhere.  Definitely worth checking the Nistune forum (or hopefully Dose knows off the top of his head) what the state of play is with that.
I'm assuming the RB25 is running the original 25 ECU? So you can't use the Nistune board in that.  You'd need an RB20 ECU to go forward, and as Dose said, you'd still be better off buying a new Nistune board, with the right program in it.  Using the S13 one would require it to be redone anyway.
You will probably find it easiest and best (although not necessarily the cheapest) to use a Haltech or other similar plug-in ECU rather than having to mess about with all sorts of additional needs to get Nistune working.
I just re-read that after failing at skim reading LOL...
You're better off with a RB20DET ECU as it supports VCT, yes that's right RB20DET can control VCT on your RB25DET motor.
If you're hell bent on using the RB26 ECU on a RB25 that also can be done, however you lose the VCT capability. All you do is wire both AFM signals together so 1x AFM feeds both inputs, however best to check with Matt at Nistune if that's still required for the later/latest firmware for Nistune.
Thanks for the replies. I may have been confusing in my choice of words. The nistune board I have is the correct type 2 board for my application. I know I cant use the rb25 ecu, but in the meantime I tried out my previous customers ancient HKS Pfc f-con piggyback from his rb26 setup, and it plugs into and runs with the rb26 ecu perfectly fine.
According to what I've found so far,  the rb26 ecu can be used successfully by bridging the maf and o2 inputs. As far as the VTC is concerned, any r32 ecu with part number 23710-04uxx or 11uxx and provisions on the board for the green diagnostic LED output can be used for vtc control, and the ecu I have fits the bill.
I guess my biggest question is why I shouldn't use the ostrich 2.0 I've already got since its supported by nistune.
Edited by turbotankshane
Having come from an S13, your Type 2 board is currently setup to run a CA18 or SR20 (or, given that you say 240SX, the truck motor that was in that).  It won't run an RB25 without having the correct programming dumped onto it.  Not just the maps, the entire ECU program (from an RB20, ideally, or even the RB26, conceivably).
There is no reason to use emulators &/or burners when you actually have Nistune......
Edited by GTSBoy
If a consult cable is $100 and the software is $200 for a license that's enough reason for me to roll with what I've got just to do some basic adjustments, hell I'm sure with a little time making an xdf I could use tunerpro rt and a modified rb26 bin to do what I needed to. It's a stock motor and turbo, I'm just looking to up the boost a little. I have absolutely no reason to put a Haltech in this car at this point in time.
I'll get in touch with Nistune and see what I can come up with though.
I think you're still misunderstanding. The type 2 board isn't for a ca/sr/ka ecu at all whatsoever. The board I have came with the car because the previous owner had purchased it specifically for an rb ecu, so it IS the correct board for an rb ecu. I'm looking on their website right now and for this bnr32 rb26dett ecu or even if I were to get any rb20det ecu, the type 2 board is still the correct board.
There is a single stanza ecu for a ka that takes a type 2 board, but otherwise for a ca/sr/ka you're looking at a type 1 or type 3 board.
Even if the previous owner had told nistune the wrong vehicle or ecu or something like that when he ordered it, I've got a base image programmer that I could put the correct base rom on the board with.
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
