25 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
  • Replies 132
Yeah not as fast but the track is way more fun, can drift on most corners and if you do come off, you dont hit tyres which block other parts of the track, but blah blah blah, it is being organised for Kingston park so that is that. If I want one out there, I'll organise one myself instead of cutting in on Mike's effort, sorry dude :)
https://www.sau.com.au/forums/topic/47630-go-karting/page/2/#findComment-963803
Slow Karts = Boring no matter how big the track...
:werd:
a track with 2 strokes would be best
kingston park I think you have to qualify in the single engine karts to move up to the twin engines, so we would only be driving the singles = a bit limp...
https://www.sau.com.au/forums/topic/47630-go-karting/page/2/#findComment-964683
Looks like Darlington Park might not be there for too much longer either:
http://www.abc.net.au/goldcoast/stories/s1058706.htm
http://www.msiracing.com.au/
But just rang them up 3382 6000 and they have a pretty standard deal:
For 10+ people for $65 you get:
1x5 Lap warm up
3x8 Lap races
1x Top 8 Sprint Race
And if we want trophies, it is an extra $70, not each, just to cover 1st, 2nd and 3rd trophies.
And they have much faster karts :P
https://www.sau.com.au/forums/topic/47630-go-karting/page/2/#findComment-964736
1x5 Lap warm up
3x8 Lap races
And they have much faster karts :D
Hey cyrus sounds Good mate if ya can give me a call & we can sort some thing out two heads better than one I always say :rant:
So Who Wants The Darlington Park Race Way Go Karting
Give Me A YES OR NO !!!
Thanks Guys Lets Get Some Thing Set
Cheers Mike:headspin:
List To Date 08/08
Oz
4 Doorz
Knore
Nexus9 (Y 4 D PARK)
Wados + 1 (Y 4 D PARK)
Strutto (Y 4 D PARK)
Melv (Y 4 D PARK)
Twoquik
RB25
Darrinspencer
Charly
Chaos
Ska (Y 4 D PARK)
Jaqule (Y 4 D PARK)
Belgarion (Y 4 D PARK)
Mick51 + 3ppl (ether D Park or Kingston)
Maybe
Growtalski
Lazy-Bastard (Y 4 D PARK)
Evo83 + 5
33 Niz
https://www.sau.com.au/forums/topic/47630-go-karting/page/2/#findComment-969534
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
