Experision of Interest
Looking at selling all my S Chassis parts.
A R35 GTR has come up for sale that I would like to purchase
Selling all my S Chassis parts including :
Work Meister S1 2Pc 18x8 +18 & 18X9 +22
Volk TE37 white17X9 +22 Brand New in Box
SIL80 with built RB25
engine:
rb25 s2
mahle pistons, spool rods
balanced & grub screwed crank
grout filled
nitto oil pump
ross metal jacket balancer
n1 water pump
oil restricters
head to sump oil drain
greddy plenum with q45 TB- ceramic coated silver
gt3076r ex/w .82- coated black
Turbosmart 45mm wastegate
tomei poncams
tomei valve springs
heavily ported head
rb26 engine covers- powder coated silica breath metallic
mines cam cover baffles
link G4+ xtreme
xspurt 1000cc top feeds
Aeroflow fuel
nismo fuel reg
Walbro 460L e85 pump
splitfire coil packs
3inch stainless exhaust
40mm radiator
air/water seperator
setrab oil cooler with themostat
blitz fmic
Turbosmart 45mmlubmback BOV
lots of braided hose
driveline:
rb25 g/box
r33 master cyclinder
exedy ceramic button clutch
1 piece 3inch tailshaft
wheels:
18x8 +18 work meister s1
18x9 +22 work meister s1
17x9 +22 TE37 in boxes
exterior:
silvia front
type x tail lights
aero front bar and skirts
gtr grill
bomex bonneville rear lip
hand flared guards
Factory S13  indicators & park lights in Box
electric bomex/east bear mirrors
respray in custom grey
interior:
R33 gtr seats
nismo gear knob
powertune 7.1 inch touch screen
180sx sr20
53352533_2099646290118288_6143280203813617664_o.thumb.jpg.7c92ea7a336557159fd49d5ea3a17acc.jpg53429858_2099645990118318_6674446943977996288_o.thumb.jpg.517f03604b4a494e60d9b5abe49aff18.jpg53435092_2099644926785091_4720704258473721856_o.thumb.jpg.9819226996096b40165b61b17515a275.jpg53732597_2099644486785135_1978835714103574528_o.thumb.jpg.a7f6ee17814d23838c845446513a4111.jpg
180sx current spec list 24 March 2019
Engine:
Standard sr20 with mls headgasket
standard intake
gtx gen 2867 .82 rear
standard manifold
3 inch exhaust
Link G4+ ecu
taarks fuel rail 1650cc injectors
Walbro460L fuel pump
mid mount intercooler piping & intercooler
Handling:
MCA Purple coilovers
Kazama adjustable Camber, Traction & Toe arms
GKtech front castor arms
S15 front LCA & knuckles
R33 GTR diff, shafs & hubs
Urethane Bushes
R33 GTR Brembo Brakes & master cylinder
dba 4000 front rotors & project Mu Rear
Project Mu Brake pads
GKtech tie rods & ends & rack bushes
Whiteline sway bars front & rear
R33 GTR wheels with Hankook 255/40/17 RS3
Inside:
Cobra Suzuka seat
Defi water & Oil Temp, Oil Pressure, Boost
Keys racing steering wheel
Outside:
Hektic 2000's era styling
Tiger mica paint
clear tail lights
Edited by robbo_rb180
  • Sad 1
https://www.sau.com.au/forums/topic/477097-eoisil80-with-rb25-180sx-track-car/
  • 1 month later...
    • The car/ECU will have all the sensor that it needs and expect to have. I think i do not have to explain to you how the Link is way better specialy if you have swapped engine   I just do not want to deal with any "problems" cuz i have only Nistune which i learned is not that great and in my case cant even deal with that speed problem (Link can) And of course it will be way more easier to tune and diagnose and safe. And for the ECU/speed problem...i dont know.
    • Per Mark Roberts of Sonictune: Mark Robert Author At this time, no. No ETA either 2016-17 models. You will be able to purchase and install a 2018.5+ TCU though   TCU purchasing and pricing info! As we near the release of TCU tuning, I am going to answer some questions I get asked often.   What do I need for TCU tuning? At this time, you will need a 2018.5+ TCU to be able to tune. If you have a 2016-to early 2018, you will need to replace your TCU with the newer version. One good way to know if your TCU is good is if you have auto upshift in manual mode in 1st gear around 6500 rpms. If your manual 1st gear goes to 7k rpm and will hit the rev limiter unless you shift, you have the older TCU.   Why do I need to buy another ecu license/phone flash if I already have it on my ECU tune? The TCU is its own computer module. It is completely separate from the ECU. Because of this, you will be required to purchase a TCU license and, if your tuner has it, the phone flash license required to tune it via phone/bluetooth.   Do I need TCU tuning? TCU tuning is NOT required. However, the faster your setup, the more it will assist in track and dragy time consistency.   If I’m ECU tuned by (tuner A) can I get my TCU tuned by (Tuner ? Yes, since it’s a different module and a completely separate flash, you can have two different tuners. However, it is highly recommend that you have both tuned by the same tuner. For me, my TCU tuning will directly complement my ECU tuning style and features and running my ECU and another TCU or vice versa MIGHT cause some issues. At this time and for the foreseeable future, I will only be tuning my current ECU tuned customers TCUs.     I have a SYVECS AWD controller. Do I still need it? Yes! The AWD controllers main job is to control your AWD system. However, with TCU tuning, you will no longer need the auto-shift function as that will be done through the TCU. The AWD controller will still be very beneficial for racers looking to maximize traction on the launch.     Shift schedule changes: holding gears longer at lower pedal input as well as max shift rpm changes. Please note, the new ECU race rom coming out will address 90% of the shitty drivability issues these cars have through custom maps from myself and Racebox—as well as others I am sure.   Increase shift speeds: as seen in the videos I’ve been posting, the TCU shifts much faster once tuned.   Increased shift pressures: as also seen in the videos, much firmer full throttle shifts.
    • The fancy pants red shock tower brace is finally incoming from MX5 Mania, getting it shipped from 'Merica has been a long and problematic process, and GWR, the 'Merican supplier will not ship directly to consumers outside of the US, Mania basically had to order a heap of them, the colour choice was silver, or red, and we all know anything red adds 5 killerwasps of dynotorques..... Whilst it does fit over a 2.5, and I've seen a few photos and videos of it being installed and fitting, google also says it might get real close to the FAB9 intake front runner, people in the US says it does fit with the FAB9 intake, except for one person who said it slightly touched.......so there is that.....LOL..... As it seems that I am the first in AU to have this combination of parts there's no local knowledge about fitment, so I'm just a willing guinea pig in this endeavour, I'll cross my fingers and toes and hope for the best In other news, I ordered stuff from China  on the same day I ordered the 23° silicone bend from Victoria, the stuff from China arrived a day ago, the 23° silicone bend is still travelling around Australia thanks to Australia Post, and "may" be here next week
    • Very good news...I contacted Racebox about it last night. My car is a 2016 so remains to be seen if it is compatible, requires a TCU swap, or is impossible.
