I'm hoping someone has a RB20 manual transmission in good shape they may have laying around.
I am from the States so I know that can be an issue for some but maybe someone hear may know someone from the states who may have one and pass the word around.
Thank you!
https://www.sau.com.au/forums/topic/477106-looking-for-a-rb20-transmission/
So I've read, but with this low hp application and the ability to use the stock driveshaft and mounting points of a Z, I'd rather keep it as simple as possible.
Pretty ironic when coming from my carburetor thread, right? haha
You seem to be real deep in this, spread the word if you can. Come up with a finder's fee!
Edited by CowboyZbop
I'm not sure I follow. The RB20DET manual gearbox is physically exactly the same as the RB25DE. You unbolt one, bolt in the other.
I was under the implication that a different driveshaft had to be used for the RB25 unless it is referring to the RB25DET gearbox?
Either way, if true and I could use the stock 260z driveshaft with the RB25, RB25 transmissions are very hard to come by here. Atleast for a reasonable price.
RB25DE gearbox is exactly the same gearbox as the RB20DET. The small frame gearbox.
RB25DET gearbox is much larger. It's the big frame gearbox that was used in Z32s, Nissan pickups (and the GTR, essentially). That box  would definitely require tailshaft modifications, although that is no problem. Every single person who has put an RB25 gearbox into an R32 here in Australia has carted the necessary parts off to the tailshaft workshop (usually Hardy Spicer) and had them cut and shut them together. Hardy Spicers have done it so many times that you don't even need to take measurements! They know the lengths off by heart. It's not hard.
I am very surprised that you think you can use the 260Z tailshaft against an RB20 gearbox anyway. I would have thought that the back end of the L260's gearbox would have been different to the RB20's.
It seems like all the way back to the Z cars that there is a lot of similarities in Nissans among the years.
All this information on this I acquired from mostly hybridz forums. The guy who has to rework my oil pan for this swap also runs the stock driveshaft in a RB20. Many users seem to have done the same.
I don't think there is. It sounds like for my application there is only 2 options. RB20DE(T) gearboxes and RB25DE gearboxes. That's not very broad in my opinion. Like I mentioned before my eye would be on the more durable gearbox but they are very elusive here.
But I do appreciate where your posts are coming from. You were just informing me that there is a better option.
There were a lot of NA Skylines, Cefiros, etc made with RB25DEs in them. There are many of these boxes still available in Japan. If you need one, don't be trying to look in the USA, where there will be almost none. Try looking at the source. Consider using Jesse Streeter or one of the other buying & shipping agents who live over there to get you one.
    • (it is a brand new ported mellings pump) I suspect the lack of pressure is due to the leak. It was *not* that low in other logs of oil pressure in the past. It wasn't that hot either, but not far off.
    • Would a Mellings oil pump be a viable option  From my time with a LS, and talking to tuners and LS specialists, the "weak" OEM oil pump is one of the first things they recommend to swap out if I was going to give the engine any high RPM I opted for a Mellings high volume, with the high pressure springs and I never had a issue with it Cost wise they are not expensive in the scheme of things
    • Just bought a 2002 Stagea 250tRS VR-X Four AERO VQ25DET and spent the last two weekends cleaning and detailing it.. still have to do the wheels and the engine bay but the rest of it came up nice. Imported 2011 to S.A. and I'm the third owner since it was imported. I met the guy who brought it over, he went to Japan and picked out the car, bought it and ordered the wheels. He also gave me a list of stuff he did to the car with receipts. Coil overs (I have the original springs), 3" exhaust from the dump pipe back no cat, Custom dump pipe,(I have the original exhaust), Plenum spacer, 18" custom Work XSA wheels (need restoring, I've made a start..), Shift kit put through the 5 speed tiptronic auto, TV and menus/screens changed to english, Australian DTV tuner installed in rear. I've just had four new discs and new pads as well as all the fluids including the brake fluid replaced. I have all the receipts for the last 15 years and the import papers in a nice folder. Car looks great, goes like hell but fuel economy is not a thing lol.. pics next..
    • I ended up in this rut again lol, and used a shit ton of filler. One thing I can't understand is, even after using a big long block and going in long X pattern strokes, I always end up at bare metal again with no filler, and my repair started at one end of the door and now I've chased my tail to almost the other end of the door. I was thinking of hitting the panel with a hammer where it might be a high spot and making everything low then filling it, I did this on a small section on my other door by mistake and I think I fixed it lol. Is this a bad idea? The other thing is with guidecoat, whether it's the powder or spray, after I sand all the guide coat off, it doesn't reveal anything for me in terms of high spots and low spots and makes it especially hard when it's bare metal (at least in powdered form), am I doing something wrong here, or likely a high spot I keep going over and creating valleys? Lastly, stupid question but, is it possible that after sanding if I only sand over the filler area where I know to be a dent that it's impossible for me to dig into that dent? Unless there are other problems which I missed.
