She needs alotta work, I'm no tuner but I can turn a wrench. I'd like to get the most out of her without doing much to the internals. She supposedly has 274rwhp right now. I need to research high flow turbos as a less expensive alternative to a nice turbo I'll need to upgrade internals for. I read around here in the forums that the high flow is good for up to 360rwhp? Can someone correct me if I'm wrong on numbers there. So basically making the most of my stock components before it turns into a racecar, I'd like a sweet street ride with giddy up before I'm violating GT300 specs ( joke ) which I don't need. I just ordered a cube premium short shifter and am about to order a gktech poly urethane transmission mount. I'd like a  Nismo cluster and can't decide on pillar gauges ? the cube speed shifter says it has a 35% throw reduction and the reason I chose the cube over nismo is that I think my gearbox is from a rb20 because the bushing is smaller on the shifter than the larger gts and gtr bushing. Even tho nengun may have found a shifter that fits I figure the cube may be better quality and has a larger reduction.. Fingers crossed!
Edited by Blue Silver
Spelling
  • Like 1
https://www.sau.com.au/forums/topic/477258-ww2/#findComment-7907356
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
