OKAY.
Anybody in Melbourne who really really needs their guides today, please call me.
I have pulled a favour at the subbies and he's cutting the panels for me right now.
Daz and Matt are coming to pick them up this arvo and if anybody needs one, for circuit racing or Auto Salon, please let me know ASAP so I can bend them up this arvo.
0419 101 639
Call me if you need to.
BASS OUT
  • Replies 175
I can wait til next week - no need to bust chops, I am sure my car will survive.
But if its not a hassle I can also pick up this weekend - but its not urgent for me mate :D
Its up to you Pete!
Ok after breaking two ring spanners I managed to get my guide on. Fits very nicely and looks great. Sidchrome tools definitely worth the price as a side note.
Will see what sort of temp improvements I see over the weekend.
Thanks.
NJR
I'm glad you like it. I think they all came up quite well.
Especially since I trial fitted every single guide to my car.
Anyway, take a photo for the guys and post it up.
Also, could you please give me a trader rating. Thanks.
And for those with Standard Bars and AFtermarket bars, here's the story.
The subbie who are cutting the bars were going to do them Friday afternoon, but as Friday's go, they didn't end up doing them.
They will be cut early Monday, and I expect to be able to ship them by Tuesday afternoon.
Sorry to Matt who drove all the way out to collect them.
Let you know Monday when they are going to be ready.
BASS OUT
NISMO BAR PEOPLE
P.S. I will also be playing around with my nismo guide.
You can see on the guides you have that there is a section which ic cut out but unbent.
This is for later modification to force more air into the intake.
I didn't want to mees around with yours as I have a lot of playing to do with mine before I can finish it. Also, there's a good chanch that when I try to bend mine it will kink somewhere and I didn't want to damage yours.
When I do complete the mods, I will take heaps of photos for you all.
BASS OUT
:D
Didn't fit. Well after buggerising around for a bit chopping off two little bits that were stopping the thing fitting on, then accidently cross threading one of the bolts (which stuffed the bracket not the bolt) I went to shut the bonnet and it wouldn't shut. I even tried sitting on it but no go.
It seems my bonnet has some bits on it that yours doesn't Bass. Not sure that I want to pull them off.
Serious?
Can you take some photos of the bit that your bonnet has please?
What little bits were stopping it going on?
I took some photos but haven't had a chance to up load them yet. Will do that tonight when I get home.
It's probably easier if I circle the bits on the photo before I post it tonight.
SHIT. I did't realise that his was a four dorr, but I'm not sure there would be any difference.
Having said that, I do remember a thread about ylwgtr's car and that he had a four door radiator support or something.....
Maybe there is a little difference.
Bugger.
4 door shouldn't be any different from the firewall forward.
http://www.skylinesaustralia.com/forums/at...achmentid=22571
see where you have put the foam stuff... I have these rubber flaps that hang down a little bit.
Ah, right.
Maybe they are factory attempts at the same idea??
If there are flaps there, it forces air to be pushed down underneath the radiator support.....
I guess.
does the nissan FAST software show car components... if it does,, it might show all the rubber under the bonnet,,
i don't have any rubber flaps!! and mine is a series II ,, talk about cost cutting bye nissan.. can someone post pics of their bonnet,, i might go to nissan and get some rubber flaps for the bonnet,, just need to know how many there are meant to be, and location,,
atleast i have the bonnet lining,, sheesh!!
afro
Ok here is two pictures. The red circles are where I had to modify. The middle one is because once the guide was on I couldn't get a finger under the latch to open it. The one on the right is not the same as the bit on the far left as it should have been but that's no big deal, I just cut it off with a hacksaw.
The pic of the bonnet is self explanatory really. The rubber flaps are held on with a bit of metal and so when you add the bit of rubber attached to the bonnet to the metal holding it on to the rubber that normally hangs down but can't because of the air guide it's all about 2cm thick.
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
