Hi guys.
I’m sorry to those who have those flaps of rubber that come off the bonnet.
This is the exact reason that you are having trouble making the guides fit.
I do not have those on my car, and it looks like they never have been there.
They are in the same place that I put the foam to stop the bonnet rubbing on the panel.
If you remove the rubber flaps, they should fit without a problem.
Again, I’m sorry but it looks like you will need to remove the rubber flaps to make the guide fit.
BASS OUT
  • Replies 175
Okay guys.
Good news. I just picked up the guide blanks from my subbie.
They are getting bent as we speak.
I will bring the appropriate amount to the Meeting tonight if anyone wants to pick them up then.
Other people, I will send them off tomorrow arvo.
Cheers
BASS OUT
GroundRun.
I'll be at the Skyline Club meeting at the pub in Hawthorn tonight from 8pm onwards, otherwise you can give me a call and pick it up between 5:30 and 7:30 from my work.
Call me, 0419 101 639
y.
Interstate people.... Your guides are all boxed up and awaiting the truck.
Afro, Erik and Coxy, you should see your guides in day or two.
Coxy, please sort out the payment, you have all the details.
Melbourne people, NismoR34, GroundRun and CNBLOW let me know when you can come and pick them up.
I'm in Mitcham or Doncaster.......
Come and git em.
BASS OUT
PS. Don't forget my trader rating and VOTE FOR MY CAR ON AUSSIEWHEELS!
NismoR34, CNBLOW
I'll be at home all this weekend, apart from the obligatory grandfinal BBQ at my sisters house.
I will bring the guides home with me, so if you give me a call, we can meet up.
0419 101 639
Tonight is good, and Sunday is also good.
Just give me a bell, and we'll organise something.
CHEERS
BASS OUT
Ground Run???
When you gonna call??
I'm bringing the guides home with me this weekend so give me a bell.
Also, could the people with standard bars take a couple of photos please??
Just want to have them on record so I know that they were right.
Cheers
BASS OUT.
ALSO< check out the new project.... AFM to Turbo Ducts.
Well done... now go and clean your engine bay, it's filthy... shame on you!
I fitted mine on too... I left you feedback Peter :( I'll take some pics later today.
:D
:D
:Oops: I working on that now!!!! hehe itll be clean soon
Thanks Matt.
I'm glad the bars all fit very well.
Like I said Matt, "Trust me, If I'm making it, it will be right."
BASS OUT
Well there was some sunshine this afternoon so I went out and took some nice shots of my car.. here's a shot of my shiny new air guide:
In the words of the Irish guys in the Guinness TV commercial, Brilliant~! :D
i have to modify mine alot (c-west front bar),
i started modifying the front bar,, but than decided to hack up the guide,,
so didn't do to much damage to the bar, will show in pics later,,
i'll have to remove the whole front lip of the guide, coz my front grill/mesh wont fit, the front lip of the guide sticks out too far,, once again will post pics later on,,
will update the changes soon,,,
thanks
Afro
Hey Bass..thanks for the guide...i went to put it on but it wouldnt fit past the bonnet unhook latch...i noticed on the guide a marking where it was hitting where i assume it was supposed to be cut but wasnt cut...after follwing the line with a hacksaw blade, i cut out a little section and then it was spot on...dont know if anyone else had the same problem with the standard bar...nevermind it fts now and looks good....
thanks.......oh and i hope u sorted out the cabbie :P
    • Ok I get you. But isn’t the butterfly intake a headache with the +T?  see this is my plan so far but please advise me into the right direction.  Nistune Ecu, 1000cc Bosch injectors, TD05 or TD06 Kinugawa turbo using stock rb25det exhuast manifold, walbro fuel pump unsure of model I think it’s 450/460, spitfire coils and sparks to suit and a R35 MAF sensor and boost sensor.    I was thinking maybe do a cheap eBay plenum $400-500 or try find a stock det neo intake. I think I’d port match it so it’s getting the full capacity but open to advice please.  Thanks
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
