1st SA post :P
  • 3 weeks later...
I'm up for a cruise, be nice if the rain would stay away!
I've installed my catch can, braided lines & anodised fittings, & finally transfered over to SA rego' with personal plates ;)
Transfer was fun NOT! but the only thing they knocked me back for was the MOMO! WTF!?!? I didn't argue though, it could've been a lot worse :) A quick swap back to the stockie & I was done ;) Then the c/can was then fitted :lol:
Joel,
Did you get a FMIC before & after dyno?
https://www.sau.com.au/forums/topic/479-1st-sa-post-p/#findComment-20060
No I didn't Matt Unfortunately.
I know before on 12.5psi it made 152rwkw with a std intake & filter 3" full exhaust & fuel pressure bleed kit.
When I had the after dyno a quick check a boost up to 14psi she made only 153.8rwkw.
The fuel ratio was around 11:1 and I saw black smokes coming out the exhaust on occasions.
There was however a heap more in the mid range, boost seemed to come on a little slower also.
For some reason it was really flattening out up top. ?
BUT...
I got home wasn't really that happy honestly so I started to fiddle removed the origional cold air intake and plumbed a ~5" duct to the origional intake in the box, I also removed the AFM mesh.
I know the removal of the mesh & cold air intake made boost come on 300rpm earlier. I did the test on Flagstaff Hill in fifth gear from 2000rpm with a flat foot before & after in the same spot.
Drivability has improved heaps and up top is heaps better now.
For example 60kays in second with no throttle, i flatten it with the 225'50 F1's with 28psi in the tyres and it starts to spin the rears then it begins gripping after a second or two.
First gear is horrid like basically it will lite up with just a little more than 1/4 throttle.
I've only done it a couple of times but with a couple of v8 commo's i've clicked in to second a little to quick and it can spin for like 4 seconds in a straight line.
it is quite fun to drive now but I need to take it easy.
I will do a dyno run before I fit the VG30BB Turbo and boost that to 1 bar..
Oh yer..
I will have to meet up with Bugalugs again and see how he goes with the 255's.. ;)
Hello 190rwkw I hope...
Hrmmm that sounds like i've been thrashing the car..
I havn't but.... well ermmmm maybe a couple of times but only to see what she can do. :)
I can't wait for the up top performance of the VG30 terbs..
I can see what ppls mean how the std turbo's run out of puff.
https://www.sau.com.au/forums/topic/479-1st-sa-post-p/#findComment-20075
Sounds good mate ;)
@ the 215+rwkw mark I removed my AFM screens & it didn't do a damn thing! I was way out of the AFM voltage range by that stage anyway.
You'll really start to see the benefit of the FMIC once the VG30 is fitted @ tuned.
It'd well worth getting your ECU re-tuned by Tilbrooks straight after the VG30 is installed (~$500 I think?) You'll really unlock the extra grunt then! Unfortunately Tim doesn't do stock ECU re-tuning so Tilbrook is your man.
With decent grip you'd give 'Bugs a good look @ your tail lights ;) With the VG30 & a re-tune you'd probably give me a good look too! Unless we do a 3rd gear rolling run :uh-huh: :)
I need some 265 FM901's, with the Falkens I get w/spin all through 2nd.
https://www.sau.com.au/forums/topic/479-1st-sa-post-p/#findComment-20118
    • Haha, i kow right? Could have bought so many cars for the same amount of money (or less) but driving Unicorn gives you at least +1mln to style 😅. Like wise man said "life's to short to drink cheap wine and drive boring cars" 😉
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
