Some time ago my Rb25 S13 started having an issue. It was idling higher than it usually would. Driving at a high rpm felt like I was getting barely any power. I posted on reddit and a lot of people said it was most likely a vacuum leak. So I did a carb cleaner test and looked for one everywhere and couldn't find anything. I was also told I should clean the IAC valve so I did that and nothing changed. Then I noticed the maf wire was laying on hot parts of the engine and it was burned badly so we bough new wire and a new maf connector and soldered all that together (I think I did it right but I could have done it wrong). Doing this did not fix the problem. I was then told we needed a new maf so we bought one for pretty cheap ($16 or 23.16 Australian dollars) and put that on the car and still nothing. It is still acting the same. Any advice would be greatly appreciated because I'm at a loss. The link below is the most recent video of the car.
https://www.sau.com.au/forums/topic/479078-rb25det-issue/
Never seen a AFM that cheap so it could be a fake.
Either way, you could try cleaning the Idle Air Controller on the back of the intake plenum, this often gets all 'carbed up' and starts to stick.
If you very carefully remove it (without dropping the screws and losing them forever) and tear it down, put some gloves on and clean all the surfaces with CRC MAF Cleaner and reassemble.
Another issue could be a faulty CAM angle sensor.
What year is the engine?
https://www.sau.com.au/forums/topic/479078-rb25det-issue/#findComment-7919269
I did clean the Idle air controller and I think the year is 89. I’m having the exact same issue as someone else and his ecu got shorted out when the maf wire got burned. So we ordered a new ecu. If that doesn’t work out I’ll look into the cas.
https://www.sau.com.au/forums/topic/479078-rb25det-issue/#findComment-7919271
    • Just to be clear, there were no lights or codes when the hiccups were occurring. Also nothing noticeable in the cars' braking. It brakes fine and the dash is clear. I only made the connection when it did throw a code and suddenly, despite the lights, it felt great again.
    • Yeah they are sliders and this was in my head before I worked out it was the speed sensor.
    • Ok so we have a smoking gun.  A few weeks ago I had to replace a speed sensor that I'd fit incorrectly. I replaced the sensor and everything was fine with no lights or codes thrown any longer.  When I was doing some more bedding in yesterday I got ABS and traction control lights again and, considering when this happens those things are disabled, the pedal went back to normal with smooth braking and no hiccups.  The codes thrown are for the same speed sensor that I replaced. When I looked at the sensor I took out it looks like the tip of the sensor is damaged. So whatever happened to it, perhaps it has damaged the magnetic ring on the bearing (that I only replaced the other week). I'll get my boroscope in the hole where the sensor goes and see if there is any damage in there. Hopefully just the tip of the sensor is in there and the bearing is fine. 🤞🏻  It's worth noting also that the pedal hiccup happens more often and for longer periods now and totally goes away when the codes are thrown again which happens usually after 5 or so minutes of driving. Love all your help here as usual guys, thanks!
    • Could you put a real seat and harness in instead of what looks like leaving your passenger balancing on a milk crate
