I just got a R33 and have been working on it just over a month now with a friend. Since received the car has had boost issues whenever it's under throttle. Sometimes the boost gauge doesn't go past 5-7psi with the car sputtering like crazy under acceleration. Other times the boost gauge shoots way past 10psi almost instantaneously. First we checked the compression to find 170-180psi across all 6 cylinders (most were 180). We then removed the plugs, cleaned them, gapped them (0.035-0.040) and re-installed. No difference. We heard an air leak from the intake side when we first got it, so we took off the manifold and replaced all gaskets and hoses. The air leak was gone but the problem persisted. We took out the factory fuel pump and filter, put in a new filter and a 340lph fuel pump. Problem persists. We tried two aftermarket manual boost controllers. We used every vacuum diagram on the web for a R33 boost solenoid (sadly there are literally guides stating that every way to run the hoses is correct). We removed the heat shield to the turbo and could move the wastegate manually, so chances are it isn't stuck. Problem persisted. We then ran a hose directly from the charge pipe (coming off the intercooler to the intake pipe), directly to the wastegate (bypassed the solenoid) which should give us 5-7psi. The problem persists.
When you're driving anywhere below 3psi the car runs like normal. It has a factory ECU with zero codes. Stock turbo, stock intercooler, stock piping. The only aftermarket mods are HKS plugs, Apexi Filter, and downpipe/exhaust. Neither of us has any idea why this car continues overboosting causing a horrible sputter. We appreciate any help this community can offer.
If it's misfiring at 5 psi or so, then it is weak ignition. Your coils are the most likely culprits there.
The boost control issue is not something that will be easy to diagnose across the 'net. Especially if you have had it apart lots. It will be something weird.
Today I hooked up a 5psi source to the wastegate, and it moves just fine.  No idea why it was overboosting.  We checked the fuel pressure and it's a bit higher than it should be, which I've read happens sometimes when you go with a higher lph pump due to the extra fuel being returned to the tank, causing a bit of a pressure buildup.  We took some coilpacks off another RB25DET, swapped them on, and sure enough that was it.  Set the timing and now she runs perfectly!   Thanks for the help :)
  • Like 1
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
    • I think Fitmit had some, have a look on there (theyre Australian as well)
    • Hah, fair enough! But if you learn with this one you can drive any other OEM manual. No modern luxury features like auto rev-matching or hillstart assist to give you a false sense of confidence. And a heavy car with not that much torque so it stalls easily.
    • Actually, I'd say all three are the automatic option. Just the different trim levels. The manual would be RSFS, no?
