Won’t be able to adjust rev limit and honestly I never get near it due to my fear of losing the oil pump. At 5k rpm boost builds with no issue no hiccups just the fact that it is a thousand rpms slower than where it should be. It’s a .82 ar so really nothing crazy. I’m going to unplug wastegate signal and go for a drive keeping an eye on boost and how fast it builds. If it behaves the same then my guesses would be cam timing is off or engine is tired/ low compression. It gave me no issues on stock turbo and manifold on 12psi.
  • 4 weeks later...
Something so stupid that I hadn't considered until I found someone with the same problem. f**kin gear ratios. how bad would they effect spool up? With a final drive of 3.9 and thick tires in the back making my effective around 3.8 that would definitely cost me 500rpms in spool right? Found someone with the same setup same power but .63 hotside spooling up at 6k. Difference between me and him is 3.5 final drive and 295 tires making his effective ratio 3.3. Could this be the answer or should I keep looking into it?
Higher numeric final drive (shorter gears) would affect the RPM you spool by because the engine will reach higher RPMs sooner. But if you were to do a time to torque/boost measurement you would find it to be faster because the engine is getting up to an RPM where it can spool the turbo sooner. You can play games with dyno load to do this, it's effectively brake boosting.
    • I transferred from full time service to Army Reserve, so I still have access, work has been super keen to get me in to work in the OPS realm, so just turning up to use the gym......and ovens, isn't causing any issues, apart from me needing to keep on telling them that I won't be doing any reserve days until I get my joint in Goulburn sorted  Basically I can now work whenever I want, for how long I want now, and it's all tax free Next time we have some fires or floods you might see me covered in mud, or cutting sick in some plant equipment cleaning up, the Reserves love getting in the news, LOL
    • Final finish outcome of 80°c was typical to the pics, I've turned the oven down to 50°c and will pick them up after the gym tomorrow  The before and after difference was amazing, the wrinkle paint has covered all of the casting marks completely It did take a couple of hours to key it all and get in all of the crevices, but, for me it was time well spent for the final outcome, but I have all the time in the world to do it at the moment  Ended up with 4 coats, each sprayed at different angles to get optimal coverage and thickness As for the fixtures and intake box thingo that hasn't made it, the supplier is apparently posting the fixtures, and, are now sending a different CAI that is in stock The replacement CAI is actually better than what I originally ordered, but will require a pod filter that locates under the front bar, still serviceable, but it basically removes the whole OEM filter box and ducts into the front bar, so filter cleaning will require ramps and the removal of some front bar undertray, not a war stopper, just some ramps and an additional 10 minutes work every few months From looking at it it is made from alloy pipe from the throttle body, through the CAI hole in the rad support, then right turning under the bar, luckily the wrinkle paint was on special and I got 2 cans for $30ish, so the alloy will get the same wrinkle treatment as the intake manifold, hopefully it turns up soon, either way, the car will be getting booked in soon, if the parts aren't here, I'll just get MX5 Mania to " make it work"
    • I'm so glad base security is so high. I see they stopped some random codger from being able to just wander in off the street... 😛   PS, intake looks good!
    • So far so good, another hour and their done
    • Exactly how each part works and how they all work together to make the engine function. That's all I'd need to do a basic build. Maybe how forced induction works. I probably need to learn some of the maths behind it all as well.
