I'm sure someone will come up with a better suggestion more local to you but here in the UK, Conceptua are a reputable dealer who stock these for the non-turbo intake and will post worldwide ...
https://www.ebay.co.uk/itm/New-Throttle-Body-to-Plenum-Specs-Gasket-For-R34-GT-Skyline-RB25DE-Neo/111878477184?hash=item1a0c7a1580:g:5D4AAOSwoydWnOLe
Alternatively use https://nissan.epc-data.com/skyline to find your model and in the engine and fuel system section find the manifold gasket and click through to the amayama shop and have it delivered from Japan. I've had stuff sent to the UK this way no problem. Import tax and waiting a couple of weeks is a pain though.
But I thought you guys over there can buy most stuff off the shelf?
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
