ahhh the memories
I have owned *takes deep breath*
Hanimex
Coleco Vision
Atari 2600
NES
Sega Master System
Sega Megadrive with CD Rom attachment (of which only 3 or 4 games were released in Oz for it)
Super Nintendo (yay Street Fighter)
Sony Playstation
Sega Saturn
Nintendo 64
Then with the advent of 3D graphics cards for the Home PC it was goodbye consoles for me :)
Many hours of enjoyment from all, but no console can compete with a Gaming PC IMHO
https://www.sau.com.au/forums/topic/48215-nintendo-or-sega/#findComment-971201
I had them all, and still do in the original boxes and all :D
In 70 years they will be worth a fortune :)
Edit, I just read Nex's post, I didnt have all of THOSE! I had NES, SNES, Megadrive, Master System, Playstation, playstation 2.
Didnt even really play them that much actually... Apart from 1992 when mortal kombat came out for mega drive :P
https://www.sau.com.au/forums/topic/48215-nintendo-or-sega/#findComment-971209
man.... megadrive was so over rated... :) even i had the cd rom attatchment and like i could never find games for them and even if i did they were over priced something chronic. :P oh well... yeh i had fun.... sometimes i put the old Snes on for some $hits and giggles. DUCK HUNT ROX!!!!! for the old NES..... i was so addicted.... but u had to set it up just right so it would respond properly when u played :D
https://www.sau.com.au/forums/topic/48215-nintendo-or-sega/#findComment-971500
I had such a huge Sega collection that I was able to sell 2/3's of it and buy my GTR :rofl:
Had a little bit of Nintendo but as far as the 8bits go, Master System all the way over the NES.
Still own:
Master System
GameGear
Mega Drive
Mega CD
32X
Saturn
Dreamcast
N64
GameCube
plus around 150 games!
One of my treasures is the Japanese version of Need for Speed for the Saturn. It's called "Nissan Presents: Overdriving GTR" and instead of porches, etc it's all Nissans :aroused:
https://www.sau.com.au/forums/topic/48215-nintendo-or-sega/#findComment-972271
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
