Hi All,
I was after some racing seats for my R32 GTR.
Not too picky about the brand (Recaro, Bride, Sparco etc.) and has to be in reasonable condition.
Would prefer rails specific for a 32 gtr but can source them separately if you have rails for a different car.
Currently got the stock seats bolted so the Nismo seat cover if any are available, I also would consider.
Thanks
https://www.sau.com.au/forums/topic/482608-wtb-racing-seats/
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
