On 31/07/2021 at 2:21 PM, NZ-GTT said:
Sorry I can't help you with the history of your car but looking at the engine bay it looks stock standard so I doubt it would have been on a dyno.
Thanks Mate, yeah looks stock but has a bigger turbo
Front mount intercooler
Apexi Power FC
HKS 2540 ball bearing turbo
Splitfire coilpacks
3" turboback exhaust
manual boost controller
GTR plumback blow off valve
Aftermarket aluminium Radiator with silicone radiator hoses
Bc Coilovers Br series
Short shift kit
blue dashboard led's
AEM Boost Gaudge
18 inch wheels Rotas
https://www.sau.com.au/forums/topic/482680-history-info/#findComment-7954422
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
