I just bought a 2008 370GT. I use to own a 2003 350GT. I found a pretty good mounting option for my phone (for nav and ODBII), with the only negative was that it blocked one of the vents, just to the left of the steering wheel.
With this 370 GT, I really am struggling to see where I count mount my phone so its in clear view, without blocking other controls. Where/how do you guys mount it?
When I was searching to buy, I did see something that looked like its mounting was inserted into the CD slot. I use the music from my phone, so I can loose the CD slo0t, but it just looks like it would damage the CD player and its mechanism.
Same issue here, same car. I was running a magnet mount on the driver’s left vent, but the metal prongs it uses inside the rubber grins eventually give out and it drops.
I’ve been considering the CD mount too. The ones I’ve seen are short for the insert, and have grips going up and down that tension once you’ve inserted it. Doesn’t go in to far.
until I get one, my phone is sitting in my cup holders, or sideways in front of the screen.
I use a CD slot mount by iOttie - https://www.amazon.com.au/iOttie-Holder-iPhone-Samsung-Smartphones/dp/B088GJBLLY?th=1
They have one that has wireless charging too.
Edited by colin.ssc
  • Thanks 1
I haven't tested my CD player. All my music is MP3's on my phone, My previous 350GT, like all others had a broken CD player, so I keep forgetting to take a CD down to the car for a test. Have you checked before and after that nothing gets borked by the CD holder? I think that location looks promising as I dont use the onboard player. The ;last guy who had the car hadn't converted it to English, and all the HDD music is K-Pop or Japanese. He leant me his Bluetooth to radio converter for my loooooong trip home.
On my 350GT, I had a long flexible arm thing that plugged into the lighter, came up to the air vent (directly above it) and I used a hidden plastic cable-tie behind it to hold the phone to the air vent. I might give a vent mount a go, with a hidden plastic cable tie. But charging will possibly be an issue, as I also don't have wireless charging (Pixel 4a), but the battery last pretty well.
The CD Mount looks good, but at worst, may be a little low.
A little low, but works for me. I don't use the CD player or the stock radio/media player for that matter. I have installed an aftermarket CarPlay/Android Auto unit for music/maps now.
Pic's or it didn't happen. 😆
Honestly though, I am curious about how it looks. Does it perform well enough? Did you replace anything, or adapt the old tech? I've been reading that some are slow to react. Which one did you go with?
I got this one
https://www.naviplus.com.au/online-store/Nissan-V36-J50-Skyline-Apple-CarPlay-&-Android-Auto-Integration-p96711064
It's good IMO, I get to bypass the HU signals by plugging the audio output of this unit straight into my sound processor. The Bose HU are shit.
Will try to get some photos later but it uses the stock screen, triggers via one of the buttons, and works when you trigger the side or rear camera.
On 2/7/2022 at 8:50 PM, colin.ssc said:
I got this one
Hey, that's is not a holder, but a replacement/extension of the system.
My problem is that what I can get my rooted phone to do, would not be practically possible on this 3rd party system. I am an android developer. Also, the audio quality and flexibility from my modified phone is truly brilliant. These same change would more than likely not be possible on a  system such as this. And hence a holder for my phone.
On my previous 350GT I built and installed a purpose built computer in my boot to replace/extend the built in screen/functions/navigation of the stock car, but eventually, I moved to using my phone. It was better, and now I had two screens at once. Navigation on one (the phone) and fuel economy on the other (the car screen)
I've tried CD mount (too low and obstructs controls), centre dash mount (obstructs view), dash mount next to the A-pillar (obstructs view) and have now resorted to letting it lay above the gear stick surround ontop of the closed ashtray. CD mount probably the best option but still not ideal imo.
I found a possible solution, similar to what I did in my 350GT. Basically, I have created a secure mount that hooks into the air-vent between the display screen and the drivers dials. I cant take a photo it, as the phone is mounted when its in its place. This first hack is a concept test. but the phone is high and its secure (I use plastic cable ties to hold the phone mount. The top of the screen almost perfectly aligns with the bottom of my screen from the drivers position (so it does not obstruct view, and doesn't require looking down). I do loose 3/4 of my air vet, but I have plans to maybe stick it out a little from the vent, thus allowing it to be on.
These cable ties are pretty unbreakable, so the phone isnt going anywhere. They are often used as handcuffs.
As I said, I basically used the same placement on my 350GT, but that was lower, and also had a bendable flexy arm thingy down to the cigarette lighter, to provide charging.
Edited by Vee37
  • Like 1
On 2/14/2022 at 12:54 PM, mooij said:
Ah yeah that looks alright. I'll grab a vent holder and give it a shot cheers mate.
Will get a photo once I'm done.
Mine should arrive by Friday (from ebay, aus location), so I will have it installed over the weekend. If you wait, I will post up pics and stuff and let you know if it works, or if my idea is a fail, before you waste ya time & money.
  • Like 1
On 14/2/2022 at 4:28 PM, Low/slow370GT said:
https://www.holdmyphone.com.au/13-15/
this is another option. A few mounting options, and then you also select the holder for the device.
Forgot to mention this is specific for the 370GT
Thanks, but one requires drilling holes in the dash. Not something I am prepared to commit to, and it looks too low anyway. And the second would mean a cable traversing across my field of view, or at least across the steering wheel column (messy)  while It was charging.
No worries, the whole thread is titled as 370GT. You may of been put off as I mentioned my previous car, which was a 350GT.
ok, the vent mount arrived today. I'll post more later, but it looks good so far.
Its basically held by the vent holder BUT I have multiple cable ties in the back ensuring it doesnt pop out.
The phones weight pushes down on the bottom lip, which closes the side holder things.
I went over some speed humps, and it was OK. But it was a short drive. I didn't spend anytime perfecting the positioning. I used the same supports (cable tie arrangements) from my previous old test holder; it positioned pretty good. The bottom right corner of the phone aligns with the steering wheel and indicator stalk. ie screen is un-obstructed while driving. And the top of the screen is much below the bottom of the winds-screen. I'll adjust it to be higher later, but its good where it is.
The only negatives so far
1. The "silicon padding" on the side is wafer thin; its like glad wrap. Expected for the cheap Chinese (delivered from AUS) I bought for $16, but it arrived pretty quick. Bought the 12th and arrived 16th, this morning.
2. The side holders align to my volume controls. So when I was first fiddling with it, it changed my volume. Pixel 4a. But was fine when I was simply driving or touching the screen or taking it in and out.
One unexpected bonus was how easy it was to put in the holder. It opens up when you take the phone out (gravity and no weight on the bottom lever), and so you just drop the phone in, and the phones weight clamps the sides in. All one handed and a single motion. My previous one required me to squeeze the sides to hold the phone.
I'll post some photos of the supports/cable ties in the coming days.
This is the one, there are plenty like it for sale on eBay.
  • Thanks 1
Surprisingly actually, this does not require drill or cutting into your dash. And that is just the mount. A holder has to be selected with the purchase.
But I do agree, it is low. I had mine in a magnetic vent mount. Honestly, shocking spot for everything except for phone convenience. Blocks a vent, and my AC isn’t as gutsy as my previous cars. I would always hit the cluster controls. The vent would always slide left and right, flinging the phone around.
hopefully your new one fairs better than my magnetic one.
I’m honestly considering apple CarPlay upgrade, unless my car sells soon.
I had a failure while driving over very rough road (potholes/construction) and quick left & right turns (left-right through some back-roads). The phone bounced out of the holder, twice within a few hundred meters. But stayed in place for the other 100km. I think a spring/elastic band to hold the opposing horizontal arms together (instead of gravity pushing down) will solve this issue. I also think if I had the charger cable plugged in, it would of stayed in place.
    • The other problem was one of those "oh shit we are going to die moments". Basically the high spec Q50s have a full electric steering rack, and the povo ones had a regular hydraulic rack with an electric pump.  So couple of laps into session 5 as I came into turn 2 (big run off now, happily), the dash turned into a christmas tree and the steering became super heavy and I went well off. I assumed it was a tyre failure so limped to the pits, but everything was OK. But....the master warning light was still on so I checked the DTCs and saw – C13E6 “Heat Protection”. Yes, that bloody steering rack computer sitting where the oil cooler should be has its own sensors and error logic, and decided I was using the steering wheel too much. I really appreciated the helpful information in the manual (my bold) POSSIBLE CAUSE • Continuing the overloading steering (Sports driving in the circuit etc,) “DATA MONITOR” >> “C/M TEMPERATURE”. The rise of steering force motor internal temperature caused the protection function to operate. This is not a system malfunction. INSPECTION END So, basically the electric motor in the steering rack got to 150c, and it decided to shut down without warning for my safety. Didn't feel safe. Short term I'll see if I can duct some air to that motor (the engine bay is sealed pretty tight). Long term, depending on how often this happens, I'll look into swapping the povo spec electric/hydraulic rack in. While the rack should be fine the power supply to the pump will be a pain and might be best to deal with it when I add a PDM.
    • And finally, 2 problems I really need to sort.  Firstly as Matt said the auto trans is not happy as it gets hot - I couldn't log the temps but the gauge showed 90o. On the first day I took it out back in Feb, because the coolant was getting hot I never got to any auto trans issues; but on this day by late session 3 and then really clearly in 4 and 5 as it got hotter it just would not shift up. You can hear the issue really clearly at 12:55 and 16:20 on the vid. So the good news is, literally this week Ecutek finally released tuning for the jatco 7 speed. I'll have a chat to Racebox and see what they can do electrically to keep it cooler and to get the gears, if anything. That will likely take some R&D and can only really happen on track as it never gets even warm with road use. I've also picked up some eye wateringly expensive Redline D6 ATF to try, it had the highest viscosity I could find at 100o so we will see if that helps (just waiting for some oil pan gaskets so I can change it properly). If neither of those work I need to remove the coolant/trans interwarmer and the radiator cooler and go to an external cooler....somewhere.....(goodbye washer reservoir?), and if that fails give up on this mad idea and wait for Nissan to release the manual 400R
    • So, what else.... Power. I don't know what it is making because I haven't done a post tune dyno run yet; I will when I get a chance. It was 240rwkw dead stock. Conclusion from the day....it does not need a single kw more until I sort some other stuff. It comes on so hard that I could hear the twin N1 turbos on the R32 crying, and I just can't use what it has around a tight track with the current setup. Brakes. They are perfect. Hit them hard all day and they never felt like having an issue; you can see in the video we were making ground on much lighter cars on better tyres under brakes. They are standard (red sport) calipers, standard size discs in DBA5000 2 piece, Winmax pads and Motul RBF600 fluid, all from Matty at Racebrakes Sydney. Keeping in mind the car is more powerful than my R32 and weighs 1680, he clearly knows his shit. Suspension. This is one of the first areas I need to change. It has electronically controlled dampers from factory, but everything is just way too soft for track work even on the hardest setting (it is nice when hustling on country roads though). In particular it rolls into oversteer mid corner and pitches too much under hard braking so it becomes unstable eg in the turn 1 kink I need to brake early, turn through the kink then brake again so I don't pirouette like an AE86. I need to get some decent shocks with matched springs and sway bars ASAP, even if it is just a v1 setup until I work out a proper race/rally setup later. Tyres. I am running Yoko A052 in 235/45/18 all round, because that was what I could get in approximately the right height on wheels I had in the shed (Rays/Nismo 18x8 off the old Leaf actually!). As track tyres they are pretty poor; I note GTSBoy recently posted a porker comparo video including them where they were about the same as AD09.....that is nothing like a top line track tyre. I'll start getting that sorted but realistically I should get proper sized wheels first (likely 9.5 +38 front and 11 +55 at the rear, so a custom order, and I can't rotate them like the R32), then work out what the best tyre option is. BTW on that, Targa Tas had gone to road tyres instead of semi slicks now so that is a whole other world of choices to sort. Diff. This is the other thing that urgently needs to be addressed. It left massive 1s out of the fish hook all day, even when I was trying not too (you can also hear it reving on the video, and see the RPM rising too fast compared to speed in the data). It has an open diff that Infiniti optimistically called a B-LSD for "Brake Limited Slip Diff". It does good straight line standing start 11s but it is woeful on the track. Nismo seem to make a 2 way for it.
    • Also, I logged some data from the ECU for each session (mostly oil pressures and various temps, but also speed, revs etc, can't believe I forgot accelerator position). The Ecutek data loads nicely to datazap, I got good data from sessions 2, 3 and 4: https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-2?log=0&data=7 https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-3?log=0&data=6 https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-4?log=0&data=6 Each session is cut into 3 files but loaded together, you can change between them in the top left. As the test sessions are mostly about the car, not me, I basically start by checking the oil pressure (good, or at least consistent all day). These have an electrically controlled oil pump which targets 25psi(!) at low load and 50 at high. I'm running a much thicker oil than recommended by nissan (they said 0w20, I'm running 10w40) so its a little higher. The main thing is that it doesn't drop too far, eg in the long left hand fish hook, or under brakes so I know I'm not getting oil surge. Good start. Then Oil and Coolant temp, plus intercooler and intake temps, like this: Keeping in mind ambient was about 5o at session 2, I'd say the oil temp is good. The coolant temp as OK but a big worry for hot days (it was getting to 110 back in Feb when it was 35o) so I need to keep addressing that. The water to air intercooler is working totally backwards where we get 5o air in the intake, squish/warm it in the turbos (unknown temp) then run it through the intercoolers which are say 65o max in this case, then the result is 20o air into the engine......the day was too atypical to draw a conclusion on that I think, in the united states of freedom they do a lot of upsizing the intercooler and heat exchanger cores to get those temps down but they were OK this time. The other interesting (but not concerning) part for me was the turbo speed vs boost graph: I circled an example from the main straight. With the tune boost peaks at around 18psi but it deliberately drops to about 14psi at redline because the turbos are tiny - they choke at high revs and just create more heat than power if you run them hard all the way. But you can also see the turbo speed at the same time; it raises from about 180,000rpm to 210,000rpm which the boost falls....imagine the turbine speed if they held 18psi to redline. The wastegates are electrically controlled so there is a heap of logic about boost target, actual boost, delta etc etc but it all seems to work well
    • hahah when youtube subscribers are faster than my updates here. Yes some vid from the day is up, here:  Note that as with all track day videos it is boring watching after the bloopers at the start.  The off was a genuine surprise to me, I've literally done a thousand laps around the place and I've never had instability there; basically it rolled into oversteer, slipped, gripped and spat me out. On the way off I mowed down one of the instructor's cones and it sat there all day looking at me with accusing cone eyes as I drove past. 1:13:20 was my fastest lap, and it was in the second session, 3rd lap.  It (or me!) got slower throughout the day as it got hotter.
