Good evening Gents,
        In 2022, which RB/CD009 shifter relocation kit comes most recommended? Do any of the shifter relocations actually manage to get the shifter back within the shifter tunnel without cutting? GK seems to require cutting, how about the new Serialnine CD999?
Thanks.
https://www.sau.com.au/forums/topic/483491-rbcd009-adapter-questions/
  • 5 weeks later...
  • 4 weeks later...
I am running a cd009 behind my rb25det in a r33 gts25t.
Serial nine shifter lines up almost perfectly in the factory hole. As far as driverability goes the 4.11 stock rear diff ratio is a bit too short, maybe 3.7s would be more suitable (on order).
Other than that the cd box seems to chatter a lot more, maybe because i deleted the dual mass flywheel.
A recent realization of mine is that depending on whether you mill 15mm off the bellhousing or go with a thicker flywheel to adapt for the CD trans, the latter probably is the cause of having to notch out the trans tunnel hole.
No idea why I never made the connection before but here we are.
  • 1 month later...
How is that 3.7 treating you?
You're probably better off going with something like the Jim Wolfe adaptor where you cut off the whole bell & use a bell off an auto, seems to work well
You can only use the JWT adapter with their flywheel. As I'm running a twin disc, I'm avoiding this by milling my bell housing down. Cheers.
    • Hey guys Long time lurker, I daily a nm35 stagea 250t rs four and I've had it for almost 2 years (very reliable 馃憣). Issues or just looking for information ill always find myself here having a read, so thought id join.  3inch stainless intake, pod filter, AM performance turbo dump pipe, 3inch hotdog, 3 and half inch stainless to 3 and half inch AM performance blast pipes. Bc racing coilovers. 18inch rims Hdi intercooler and trans cooler soon.  Here's my car
    • thanks for the advice on the box... i was thinking the 6 speed was better for cruising on the highway but on closer inspection and comparison the Rb 5 speed box was not too different...  So the choice is going to be the RB25 box... if I can save up and find one at the right price
    • Thanks Matt, yes that's what i am aiming for. Just going to apply the right voltage and grounds to the dash connector. Hence my search for these pins... any chance you know if these pins are in the same spot as the ones on the S15 Dash connector? as mentioned above on page 8?
    • Yes, unfortunately that's the one. Signal was noisy to begin with; after driving once and looking back at the logs I saw pressure constantly swinging between 0-200psi, or staying at 0 randomly for a few seconds. There's a lot of good sensors that share the same look and feel, so don't presume they're all bad. I bought mine for 20$ off Amazon and I should have read the reviews prior, as it's clear they're junk.  I purchased a lowdollerr motorsports sensor.
    • wedding eh.....I seem to get to more funerals than weddings or christenings these days....
