i am not trying to take business away from you but if anyone has a decent internet connection you can download them please check out the following link. It has same engines as above.
http://www.skylinesaustralia.com/forums/sh...ight=r33+manual
on the second page i have posted 2 links plus others have now uploaded them too. not sure if its exactly the same or not. if not feel free to delete this post.
is there a trick to getting the manual?
I did what you said in emule, but i never find any files when i do the search??
yeh the trick is it takes ages to download so u buy the original with extras from me.
alrite if ur tite download it.. make sure u have a decent virus protection program.
anyways if you want to deal with something professional, pm me for the disk.
dude dont start telling people bs stories about downloading it did you buy the manual yourself which i highly doubt and even if so you should NOT BE RESELLING IT FOR A PROFIT every other person on the forums would be charging the cost of a cd and postage which is at max $5 not a $15 profit for u... cant believe this hasent even been shut down...
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
