I sold the Nismo LSD to Fatz for one of his fleet and am using a Cusco instead, this needs GTR stub axles which are made of whale tears judging by the price. For the 3.5 ratio I'm getting a set of gears from Neat, I'm also building a 3.7 for Winton just in case.
The 350Z conversion is not as simple or as good as you'd hope. The front mounting 'ears' on the diff case are not in the same position from a height point of view so you end up with the diff hanging down much lower than a 'normal' R200. This creates some dramas with driveshaft angles. A guy I know has this setup in his S14 and needed to get GTR driveshafts to make it work which are also made from whale tears so it ended up being a very expensive conversion. Although the gears from Neat are $2k for a set, it probably would have been a better option with the benefit of 20/20 hindsight.
  • Thanks 1
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
