I have recently installed a FMIC and since doing so my standard ecu has been maxed out. I get boost cut(?) at about 4500-6000rpm in every gear. I was wondering what i should go for. I know the powerfc is obviously better, but i probably wont do much more to my car. I was only aiming for about 200rwkw and i doubt i will ever change the turbo. I just want to run the stock at about 12psi.
Will the SAFCII solve my current problems? If anything else was to be upgraded it would probably just be a fuel pump or something small so it's not like i have big plans for the car. Just want a nice cruiser.
anyway so far i've only got a 3" exhaust, FMIC and turbosmart boost controller.
https://www.sau.com.au/forums/topic/48493-safc-or-powerfc/
The SAFC11 will solve your probs if you get a boost cut defender as well. My suggestion if you want to make 200wrkw is to add up the cost of a boost cut defender and the SAFC11. Then look at the prices of the uni chips and other piggy backs. If the prices are close then go for the later as the UNI chip does ignition as well...
https://www.sau.com.au/forums/topic/48493-safc-or-powerfc/#findComment-974955
What you're experiencing is more than likely a misfire due to overfueling and subsequently your timing being retarded... not boost cut. If it feels fine after 6000rpm, then it's not boost cut.
if you don't want to spend much money, then go SAFC. If you dont mind spening $600b- $1000 extra (for the difference in the cost of the unit + tuning), then go the PFC. For the cost of the e-manage + ignition loom + tuning (which I think is more expensive as most tuners are more proficient with PFC which keeps costs down a little), you might as well go for the PFC.....
I got 200rwkw with a SAFCII + front mount + 3" turbo back + 9psi, I dont see why you cant hit that figure with 12psi + SAFC + good tuning
https://www.sau.com.au/forums/topic/48493-safc-or-powerfc/#findComment-975069
Guest Robo's
how much of a difference would you say the exhaust cam gear made Robo?
Not just in terms of rwkw, but in terms of tuning?
what made you decide to get it?
Maybe 5-8 rwkw, not too much, i didnt find heaps of difference but every little bit helps now when searching for every little kw.
https://www.sau.com.au/forums/topic/48493-safc-or-powerfc/#findComment-975376
Hey what can i say...any ECU that lets me piss around with it at home has major novelty value for me :P
Leave my timebomb out of it...it's almost ready for some *real* tuning LOL
finally, someone who isnt sensitive to some shit stirring! But i do really like the idea of being able to work with it yourself so easily and alot to be learnt about tuning right there i think.
-rb25
https://www.sau.com.au/forums/topic/48493-safc-or-powerfc/#findComment-975788
mm thanks. Am leaning towards a SAFCII. Are they easy to tune? my mech. has never used one before I don't think, but he's done Wolf ECUs before. He should be able to work it out you think?
I cant find a price for purchase, fitment and tune of the e-manage. Anyone care to devulge this info?
https://www.sau.com.au/forums/topic/48493-safc-or-powerfc/#findComment-976512
Comparing to the SAFC isn't really fair....the SAFC can't do a fraction of what the e-manage can. The main thing to remember is people with Autos can't use the PFC.
And with the e-manage you get laptop software that a 2 year old could use, PFC isn't so simple and is time consuming especially if people are using the hand controller to tune.
You've really got to look at what your end use will be, I don't think the SAFC really has the tuning resolution required for any decent engine upgrades....E-manage allows injector upgrades/ AFM upgrades etc etc.
I'd go a PFC if you have a manual, and access to a decent tuner.
Dan
https://www.sau.com.au/forums/topic/48493-safc-or-powerfc/#findComment-976660
I wouldn't say a fraction...
E-manage is better than SAFC, but for what this guy wants ~200rwkw, I wouldn't bother, as you can easily achieve this with a SAFC.
the e-manage in terms of tuning has a better resolution for fuel mapping, and allows you to re-map (or alter) ignition maps with the ignition harness.
SAFC also allows you use Z32 AFM as well.
The resolution on the SAFCII is pretty good.. I got my A/F ratios to a flat 12:1 (with the exceptio of 1 tiny dip where it goes to 11.5:1).
So yes, e-manage is better, but for the goals we are talking about here, the price, effort for tuning, and cost of tuning mean the SAFCII would be a better option.
https://www.sau.com.au/forums/topic/48493-safc-or-powerfc/#findComment-977226
I agree, on a manual Skylines I don't quite understand where the Emanage fits in. An SAFC is $400 and facilitates control over a/f ratios pretty well with a bolt on turbo. A PFC is $1.1K and enables control over fuel and ignition and a number of other parameters and easily handles a large range of mods.
If I add up how much an Emanage (fuel and ignition) costs including fitting (PFC's just plug in) don't I end up spending more than a PFC? :headspin:
https://www.sau.com.au/forums/topic/48493-safc-or-powerfc/#findComment-977266
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
