I have recently installed a FMIC and since doing so my standard ecu has been maxed out. I get boost cut(?) at about 4500-6000rpm in every gear. I was wondering what i should go for. I know the powerfc is obviously better, but i probably wont do much more to my car. I was only aiming for about 200rwkw and i doubt i will ever change the turbo. I just want to run the stock at about 12psi.
Will the SAFCII solve my current problems? If anything else was to be upgraded it would probably just be a fuel pump or something small so it's not like i have big plans for the car. Just want a nice cruiser.
anyway so far i've only got a 3" exhaust, FMIC and turbosmart boost controller.
https://www.sau.com.au/forums/topic/48493-safc-or-powerfc/
The SAFC11 will solve your probs if you get a boost cut defender as well. My suggestion if you want to make 200wrkw is to add up the cost of a boost cut defender and the SAFC11. Then look at the prices of the uni chips and other piggy backs. If the prices are close then go for the later as the UNI chip does ignition as well...
https://www.sau.com.au/forums/topic/48493-safc-or-powerfc/#findComment-974955
What you're experiencing is more than likely a misfire due to overfueling and subsequently your timing being retarded... not boost cut. If it feels fine after 6000rpm, then it's not boost cut.
if you don't want to spend much money, then go SAFC. If you dont mind spening $600b- $1000 extra (for the difference in the cost of the unit + tuning), then go the PFC. For the cost of the e-manage + ignition loom + tuning (which I think is more expensive as most tuners are more proficient with PFC which keeps costs down a little), you might as well go for the PFC.....
I got 200rwkw with a SAFCII + front mount + 3" turbo back + 9psi, I dont see why you cant hit that figure with 12psi + SAFC + good tuning
https://www.sau.com.au/forums/topic/48493-safc-or-powerfc/#findComment-975069
Guest Robo's
how much of a difference would you say the exhaust cam gear made Robo?
Not just in terms of rwkw, but in terms of tuning?
what made you decide to get it?
Maybe 5-8 rwkw, not too much, i didnt find heaps of difference but every little bit helps now when searching for every little kw.
https://www.sau.com.au/forums/topic/48493-safc-or-powerfc/#findComment-975376
Hey what can i say...any ECU that lets me piss around with it at home has major novelty value for me :P
Leave my timebomb out of it...it's almost ready for some *real* tuning LOL
finally, someone who isnt sensitive to some shit stirring! But i do really like the idea of being able to work with it yourself so easily and alot to be learnt about tuning right there i think.
-rb25
https://www.sau.com.au/forums/topic/48493-safc-or-powerfc/#findComment-975788
mm thanks. Am leaning towards a SAFCII. Are they easy to tune? my mech. has never used one before I don't think, but he's done Wolf ECUs before. He should be able to work it out you think?
I cant find a price for purchase, fitment and tune of the e-manage. Anyone care to devulge this info?
https://www.sau.com.au/forums/topic/48493-safc-or-powerfc/#findComment-976512
Comparing to the SAFC isn't really fair....the SAFC can't do a fraction of what the e-manage can. The main thing to remember is people with Autos can't use the PFC.
And with the e-manage you get laptop software that a 2 year old could use, PFC isn't so simple and is time consuming especially if people are using the hand controller to tune.
You've really got to look at what your end use will be, I don't think the SAFC really has the tuning resolution required for any decent engine upgrades....E-manage allows injector upgrades/ AFM upgrades etc etc.
I'd go a PFC if you have a manual, and access to a decent tuner.
Dan
https://www.sau.com.au/forums/topic/48493-safc-or-powerfc/#findComment-976660
I wouldn't say a fraction...
E-manage is better than SAFC, but for what this guy wants ~200rwkw, I wouldn't bother, as you can easily achieve this with a SAFC.
the e-manage in terms of tuning has a better resolution for fuel mapping, and allows you to re-map (or alter) ignition maps with the ignition harness.
SAFC also allows you use Z32 AFM as well.
The resolution on the SAFCII is pretty good.. I got my A/F ratios to a flat 12:1 (with the exceptio of 1 tiny dip where it goes to 11.5:1).
So yes, e-manage is better, but for the goals we are talking about here, the price, effort for tuning, and cost of tuning mean the SAFCII would be a better option.
https://www.sau.com.au/forums/topic/48493-safc-or-powerfc/#findComment-977226
I agree, on a manual Skylines I don't quite understand where the Emanage fits in. An SAFC is $400 and facilitates control over a/f ratios pretty well with a bolt on turbo. A PFC is $1.1K and enables control over fuel and ignition and a number of other parameters and easily handles a large range of mods.
If I add up how much an Emanage (fuel and ignition) costs including fitting (PFC's just plug in) don't I end up spending more than a PFC? :headspin:
https://www.sau.com.au/forums/topic/48493-safc-or-powerfc/#findComment-977266
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
