Hi all i’m bit of a noob when it comes to wiring.. anyhow I recently installed an r35 maf on my r34gtt neo. I extended the wiring to the maf which sits in the cold side IC pipe. I load up nistune and instantly greeted with a warning saying
MAF voltage exceeded 5V! Check MAF is not reaching maximum capacity”
I used the picture below to wire it up. Have I just wired it up wrong perhaps or maybe MAF is bad ? It wasn’t new I got it from a breaker yard but genuine nissan.
Thank you.
https://www.sau.com.au/forums/topic/484938-maf-voltage-exceed-5v/
Then probe the wires at the AFM, work out what's what, and start from there. Something is clearly wrong, but we can't tell from here what it is, so you need to investigate the actual situation in front of you. Also probe at the ECU end of the signal wire, just to make sure you know everything.
