Regularly when I warm start my 2001 Skyline (300GT Sport) it starts, revs up a little as it should, then the idle drops back down, but to somewhere below 100RPM, and all but stalls. I've never had to actually startthe car again, it always catches it, but it's been slowly getting worse the last year or so, to the point that last weekend at Bunnings, the tacho actually read 0 RPM. There's no check engine light, nothing in the OBD logs etc. Is there anything common that would cause this, that I need to pay attention to?
Cold start is fine, and it's not every time it does a warm start. With the exception of some laboring from the AC pump, the car is great condition for its age. I'm the 3rd owner (1 in Japan, 2 in NZ), always been garaged, serviced etc.
https://www.sau.com.au/forums/topic/484971-v35-almost-stalling/
I'm not too sure about the DD engines, but on a DE I would suggest you start with a throttle body clean and an idle air volume learn procedure.  Would be worth cleaning the MAF with an appropriate cleaner too.
5 hours ago, GTSBoy said:
Do these things have an e-throttle, or are they still using a AAC/IACV for idle control? If the latter, take it off, take it apart, clean it thoroughly with carby cleaner, parts cleaner or brake-kleen. it'll be full of gunk, sticky, and slow to move.
It's DBW. Easiest place to start is make sure the throttle body isn't clogged up too badly. Long term fuel trims will also give some idea of what's going on.
Just an update on this: I had a busy weekend doing home DIY, haven't had a chance to look at it, but this time on Sunday evening it actually properly stalled and I had to start it again. Check engine light came on after the stall (as to be expected), but I haven't checked any logs etc yet.
Weirdly, the lowered V35 has become our 'practical' car. We also have a V37 Hybrid, so the ski hole (which is missing on the Hybrid, as the batteries get in the way), ability to tow friends broken down cars etc has made the V35 (towing seem to be a hybrid no-no) has made it our practical car hah. I'm half tempted to fit a tow bar to it, but that seems a bad idea.
You can tow with the Q50/V37 hybrid, but you really need to be careful pulling anything up an incline at very low speed, like a boat ramp.  These cars don't have a torque converter in the transmission and rely on the low/reverse brake to act as a clutch at very low speeds (lower than idle speeds in 1st gear) and they don't like to slip for extended periods.
That said, it probably isn't too wise to tow anything heavier than your average box trailer.
Edited by sonicii
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
