So i got a 97 stagea with rb25 and it’s having issues running it starts runs for a good 10 or so seconds than shuts down used to run horrible for a few seconds till i cleaned what i believe is the IACV now it runs healthier but still shuts down previous owner ran the fuel filter backwards before realizing than putting it the right way. Cam angle sensor was replaced aswell some things are unplugged under the dash and i have no clue where they go cause previous owner did some uhhh funny wiring theres also a random plug in the engine bay where i have no clue where it’s home is lol. Vacuum is good and spark is good even when running so i’m at a loss previous owner also ran regular and i was told it needs at least premium. I guess i’m kinda lookin for some tips on other things to check i probably left out a few things i checked. Thank you all
https://www.sau.com.au/forums/topic/485897-rb25-starts-but-wont-run/
Hi and welcome to :sau: !
I'd be taking some pics of the plugs and wiring you've found and posting them up. The guru's on here will be able to get more from those than your descriptions of them. :)
I will try to get some pics today if i remember haha how would i go about putting them on here is there a way to do it from a phone it says i need a link? Thank you!
With the idle, have you reset the base idle screw with the IACV unplugged?
Very likely the base idle is set far too low. 10 seconds sounds about right for the ECU keeping the IACV open at about 1000rpm, then it should settle for about 650-750rpm (I can't remember the exact rpm point). If the base idle is too low, it can cause the car to stall.
I believe so haha don’t quote me on it my old shop foreman is helping me out. I also totally forgot to mention cause i’m a dumb dumb when you even try to give any throttle it chokes it out quicker if that’s any help. I gave the MAF a clean really wasn’t that dirty. He recommended i check the o2 sensor one day idk if that will have any effect?
56 minutes ago, PranK said:
Just click/tap the link at the bottom of the editor that says 'choose files'.
Here's some photos of wiring i cannot find the homes for the first one i didn't realize till after has a few more hidden behind them so there's a couple more but that's what i could find. Thank you!
I'd try to send the video of it running but idk if that's possible? Sorry I'm very new to this i usually work on old american cars so this is all very new to me lol
I don't even know is those worked i can no longer see them
Those didn't work. Depending on if you're on a phone or PC, you can click the add files button, select each photo one at a time (pick one photo, tell it to upload, click 'add files' again.)
It sounds like a few things are unplugged, one is possibly the AFM (or wrong AFM) or the TPS.
I've had the same issue before too leaving the temp coolant sensor unplugged, but that only became an issue once the car got hot.
To know what the base idle is doing, unplug the IACV (electric plug to it), and see if it'll start up, and what the idle tries to sit at. It will be interesting if it can even start with the IACV unplug, and that would be a big clue too if the idle screw is set too low.
Will wait for the pictures to load again so we can check plugs.
It does start with it unplugged it ran a lot healthier after i cleaned it out a bit it still kinda idles rough sometimes and shuts down quicker but when it sounds healthier it runs longer but even when you attempt any throttle it like instantly chokes it out and the car is like NOPE no throttle for you lol. also only options i have to put photos are to only use links or URL and that is what i did and i could see the photos till it refreshed and now i can't see them lol
1 hour ago, GTSBoy said:
You can't post images until you have like 10 posts or something.
My apologies @Harley80 I forgot about what @GTSBoysaid. I have fixed this for your account now so you can upload images.
  • Like 1
  • Haha 1
Oh hahaha i thought i was missin something lol
Here’s a video of what it’s doing excuse my finger we lost that plug when i took the video but found it yesterday. That’s when it sounds a lot healthier sometimes is really struggles to idle and chugs still it shuts down
Edited by Harley80
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around with a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
    • Yep, this bit another local owner. I caught it before putting the transmission back into the car, what I noticed was the pressure plate fingers weren't flat and even. It's more obvious with the pull style clutch because the throwout bearing ring was visibly not flat once everything is put together. Nismo should really update their instructions to call out this specific detail. I'm not even sure the clutch as-shipped orients everything properly.
    • It ended up being that orientation of the float hub in relation to the clutch disk, when I installed it, I heard a loud click and being stupid, I decided to not take it a part and check it. The hub didn't properly align with the clutch disk and was causing the issue. Definitely an odd one! Dahtone Racing was able to fix me right up, stand up blokes!
    • Right, but I'm saying on the stock ECU measured airmass from the MAF is no higher than stock. So it's accounting for the higher flow rate iso-manifold pressure. You just have to keep turning down the boost until you're within the stock tune's load scale. If you run off the end there's no telling what will happen. This does mean there's zero benefit to the turbos you're running vs stock, if anything it's just a straight downgrade because the transient response is worse, you don't even get the ECU's boost solenoid helping to pull the wastegate closed during initial spool, and peak power is only whatever the factory map can give you before you hit the R&R corner. On a -9 I would bet that you would have to change out the wastegate spring once you have a real ECU and you're tuning it for real. I'm not saying this is a remotely ideal state of affairs, it's just a way to keep it driveable until you can get a proper tune done.
