It wasn't an rb30det,was just an RB30ET...It was from adelaide and i was fortunate enough to get a ride in it at one stage...It hauled ass :D:(  I've got the link at home for it (its a mate of mine) i'll post it when i get home if i don't find it here at work whilst searching for it!!
Faaaaaaaaaaaaaaar out!
That changes my mind, but today the L28/3.1 stroker got expensive with all the bits and no available pistons suitable for turbo.
Think better plan is go the RB conversion, but keep all the stock PNV bits, just in case needed for return to standard.
Still could be just as rare.
  • Replies 48
I really would like the link to that site , if you have it could you post it please !
Thanks A  .
Your wish is come true...http://nissanking.sphosting.com/r30/index.html try that link see if it works
So much to research . I thought bonnet clearence would be a problem (3liter twin cam) so looked into GTR bits . Turns out that RB26 manifold bolt paterns are different so 20/25DET exhaust manifold won't fit . If anyone knows how they differ please tell - thoughts of adapter plate .
Otherwise its back to early 25DE head on RB30 NA bottom end with RB20DET loom and PowerFC . Injectors could be R32 GTR (440cc) with spliced in resistor pack . I hate this bit but the 120 deg bend off the throttle body will point back towards the intercooler outlet .
Am going to look into the R31 front cross member to see if it bolts into R30 . Strip your own wreckers are good for finding out this stuff . If it works it'll get me a power rack and suitable controll arms with replaceable ball joints and RB type brackets . If bonnet clearence becomes a problem I'll look into spacing down the cross member radius arms and strut feet - thats after getting the sump as close as practical to the cross member . Can anyone see any holes in this plan .
Thanks Adrian .
Ghostrider , I came across an interesting site called Handy Dandy Denny (stupid name) from the US about Zeds . HE said they used either Z24 or KA24 pistons in stroked ( LD28 crank) L28's . The current 4 cyl Navara uses a low compression like 8.4 KA24 twin cam motor , these pistons could be worth looking into .
Thanks  Adrian .
Hey Disco,
Nothing wrong with RB25/30DET, that's where I'm going now. Those KA24 pistons are to high a comp with 89mm bore, but it was getting expensive (L28 stroker), as I had to acquire all the bits again.
My RB25/30 DET has 87.0mm bore, 'O' ringed block, Wiseco forged pistons, flowed & ported RB25DE head, HKS cast exhaust manifold with 45mm ext gate into 3.5 inch dump, Trust/GReady inlet plenum/manifold assembly, S4 RX7 550 injectors, RB25DE throttle body, Z32 AFM, custom air box, HKS full flow air filter, FMIC and presently a flowed T03, but a Garrett GT3540 is coming.
All driven by a re mapped R32 ECU. Maybe an Apexi Power FC will come later or a fully programmable ECU, depending on HP requirements.
The exhaust manifold, turbine housing, air box and all connecting pipes are being HPC coated.
All this should give me about 350Kw at the treads on 18/20 psi boost.
The R31 cross member is very close to same width, but the mount holes are wider apart. If you have to go through engineering you will need to fit anti crush sleeves into the chassis rails. The idea is good, but it will take some f@#king around getting it right and quite frankly, I didn't think it was worth it, as I already have a full set F & R of JIC Coilovers for the R30 and DR parts (brakes) just bolt on.
Also the R31 track is 24mm wider.
I might look at it later again after i'm registered but not before, and after, I still may not worry, as I have 2 spare power steering boxes.
There are far more important things than rack & pinion steering.
Thanks Ghostrider . I have also been looking into GT3040 and GT3540 . The Ford XR6T uses a GT3540 with integral wastegate . The compressor housing AR is .50 but not sure of exhaust side AR . Suspect 1.06 because of the four litre donk . This may be the answer for those wanting five litre power rather than six .
Am keen to see the pics of your HKS cast exhaust manifold and Trust/Gready plenum . It also looks like you know someone who can re program the Nissan ECU in Sydney .
Your project will probably get moving before mine as I need to sell the spare FJ bits to make room for RB stuff . The parts gathering will start soon , when I work out which head and manifold combination best suits me .
Cheers A .
RB30DET will almost certainly have RB26 Head and Inlet Manifold . My reasons are , non VVT RB25DE = $950 GReady Inlet Manifold (which I've been told by several tuners dosent work the best) = $1050 + better injectors = $480 all up comes to nearly 2.5G with lots of junk to store . RB26 for $2000 + gives you better cams / springs / porting / injectors / sodium cooled exhaust valves AND the 6 throttle inlet with probably cooling benefits ie designed to live on higher output engine . I'd bet it will breath more easily and give more power per pound of boost so not requiring mega boost levels . The RB26 ecu/loom could also run it although with 2 MAF's .
  • 3 weeks later...
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
