I wouldn't think it would be all that hard. Any decent body shop would be able to do it for you.
What kind of kit are you thinking of getting?? I am looking for a decent kit for my R34, but have yet to find one. The Do-Luck kits are so-so, and I don't know whether Veilside make one for the R34 GTT. Anyone??
bonnet is the same length. the guard is wider. front bumper and rear bumper supports are different. you'll probably need to get adapters made to fit a larger/wider bumper. maybe $100 for all the adapters. also the sideskirts mount differently to the guards on a GT? compared to a GTR, so you'll have to come up with some clever way of makin those fit.
maybe GTR front guard, r34 gtr front fenders and keep the rest as gt and get the standard kit.
yes, but if you are putting a GTR front bumper on the car then the shortened GTR bonnet is rectified innit?
OK dimensionally the GTR bonnet is shorter... but I think it should fit into where a GTt bonnet goes properly as long as you put a GTR bumper on as well to cover the gap... that's what I mean...
yeah you need to break out the angle grinder on that thing...chopskies!!!Not that I've looked into it or anything :)
Either way the GT-t bonnet needs to be modded a little bit. And the GTR front spoiler needs to have some slight "massaging" to get it on without that bulged look from the sides being pinned in.
Okay, so im just going to put a GTR bonnet on it, front fenders, front bar.. it will all work out, the side skirts will be fine, the only thing now is the rear bar, as teh rear flares on the GTR i think the bar will need to be remoulded and pushed in at the tips....
thanks for your help guys :P
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
