Originally posted by Duncan
Hey 1394, are you the bloke that was at wakefield the other day, or is nowra just dripping with Skylines???
no, not me.
there is a few skylines down here, but thet all seem to be different models, where i live the is a 32 gts-4, 33 gts-4 a few 33gts-t and a couple of 32gtr's
as far as i know im the only one with a 32gtst.
bet you cant say that in sydney.
https://www.sau.com.au/forums/topic/4866-skylyn/#findComment-76125
u mean SKYLNE?
muhahahaha dofito selectah!
we paid him out too much for having different colour panels so he went and got the whole car panel beated and primed now and its getting painted in a few weeks when hes got money.
looks like someone chucked a big box of custard on the car :D
and on another note, i have *finally* booked my car in to get FIXED! :uh-huh:
https://www.sau.com.au/forums/topic/4866-skylyn/#findComment-76375
Originally posted by 13ninety4
no, not me.
Can't say that in sydney!?
F00K OaTH we can,
where i live, theres countless R32 GTRS and a frew R33 GTRS, and as for R33/R32 GTST, mate, hard to drive down the street without seeing one.
:D
https://www.sau.com.au/forums/topic/4866-skylyn/#findComment-76497
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
    • Yes it is ATF. I quote @Duncan "it takes a good synthentic auto trans fluid like Castrol Transmax Z" It's not a diff. It's a transfer case. Totally different thing. Yes, fluid will come out the sender hole. No you do not really need to drain it. Just pull the old, quickly poke the new, clean up and top up. But realistically, you should probably take the opportunity to change it anyway.
    • Hey all. I’m looking on replacing my speed sensor on my R33 GTR. Will the center differential need to be drained, and if so, the center diff uses ATF fluid D? I found information on the transmission, front diff and rear diff. Can’t find a for sure answer for the center diff. Any help will be greatly appreciated.
    • I would tend to agree, especially based on the transfer oil being completely cooked by the sounds of it. I bet it was serviced every 5,000km... Which probably worked out to once every 15,000 real kms...
