R33 GTR motor Question
Guest cop_zilla_69
I have a non turbo R33 gts 95 r33 M spec.
A .Can i put an r33 GTR motor in it , engine mounts, wiring etc with out to much trouble.
B .I live in brisbane aust how much would it cost to import a secondhand reconditioned GTR motor.
C .I can either do the above with gtr bodykit,mags,badges or would it be a better idea to sell my car buy a decent r33 gts-t and attempt to bring it up to 300kw
Thxs opinion appreciated
https://www.sau.com.au/forums/topic/4913-r33-gtr-motor-question/
Sell the thing and buy one that was fitted with a turbo standard.
Why you might ask well:
the na has weaker
diff
suspension
breaks
ect...ect
the cost of upgrading all of the things to a gts-t level would be much much more than the differance of the two cars, therefore if ya want a turbo, buy a car that was built with one (or Two) from factory.
DAMQIK.
Call me a picky bugger, but there's no such thing as a non turbo "M spec". M spec designates the turbo version of the R33 RWD range.
You've made the right choice, selling & starting with a turbo model.
Sounds to me like 33GTS-4 with big brakes fitted. If it is, then you could also consider getting a GTR front cut and swapping in all the bits. This would be the low cost way, but is a lot of work.
If you sell your car and buy a GTR it is going to save a lot of trouble, but cost more. Depends on how you value your time, and if you have the tools, knowledge, and facilities I suppose.
Hippy,
That’s what I call “taking me literally” :lol: :mad:
CK69,
The range of factory options for the R33 (& other models) is huge! The factory body kit could be selected on the turbo or non-turbo. Pitty they didn’t offer 4WD as an option (except the GT-R). If your R33 has 4WD & isn't a GT-R then it the R33 GTS-4.
i know what you mean! i saw the prices too and i nearly cried... didnt full on cry though... i'm strong :lol:
BTW: anyone know how much for 1JZ and 2JZ engine? are they more or less expensive than a GTR motor? coz in terms of build quality, they are about the same.
Originally posted by Silver-Arrowz
The cheapest I've seen a GTR motor for is $6500.
Add all the bits that you need plus fitting and you'll probably cry.
It is in it's own way a better motor. 2JZ have more and better torque than RB26. Also more reliable cause it's doesn't rev as hard as the RB26.
I assume it would also be expensive.
I reckon the beat bargin motors going around are the RB20's.
The 2JZ-GTE is 3 litres, it has the same 86mm bore as the RB26, but the stroke is 86mm. Sort of like an RB30DET. If the bore is the same in both engines, the valve and port sizes are most probably also the same or very close.
I have no idea what a 2JZ-GTE costs, but I doubt if it would be all that cheap either.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
