  • Replies 53
I have no issues with the law with my car. most of the time they scratch their heads :cheers:
Ive been pulled over racing my mate (r33) and we were both still under the speed limit after accerelating very hard from the lights to 70km/h.
He had to pop the bonnet and they didnt even bother looking at my car. LOL
Although they kept scratching theior heads as well thinking WTF is this car and why does it have such a large zorst.
  • 3 weeks later...
i got fined the other day in my cef but the cop was so friendly he didnt give me a defect even though he spotted a few probs lol.
fined for what? were u speeding? :)
yeah i wouldnt mind meeting up with a few of u... u should all come on the sau vic cruises and stuff... go to the vic section.
