  • Replies 53
I have no issues with the law with my car. most of the time they scratch their heads :cheers:
Ive been pulled over racing my mate (r33) and we were both still under the speed limit after accerelating very hard from the lights to 70km/h.
He had to pop the bonnet and they didnt even bother looking at my car. LOL
Although they kept scratching theior heads as well thinking WTF is this car and why does it have such a large zorst.
  • 3 weeks later...
i got fined the other day in my cef but the cop was so friendly he didnt give me a defect even though he spotted a few probs lol.
fined for what? were u speeding? :)
yeah i wouldnt mind meeting up with a few of u... u should all come on the sau vic cruises and stuff... go to the vic section.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
