I noticed a funny smell inside the car over the last 2 days......anyhows my car was filthy so i thought i'll clean it before going out friday night. I start taking out the floor mats when i notice that the passenger front mat is wet. I lifted out the mat, and the carpet underneath that was wet too.
I got some white kitchen towel, and started mopping up this light green coloured liquid ( coolant i assume?!?!) anyhows i pop the bonnet, and open up the coolant bottle and the coolant is boiling hot and bubbling/steaming.
My questions are -
1) what is that liquid leaking into the passenger foot well and where the hell is it coming from!!
2) why is my coolant bubbling/boiling?!?!
HELP!
https://www.sau.com.au/forums/topic/49289-help-plz-read/
ok did a few more checks.
radiator had jack shit coolant in it, must of put another 2 litres into it. I got a torch and shined it above the coolant bottle, revved the engine and there were bubbles n shit but you cant see them from looking directly down the hole u have to look sideways into the back of the coolant bottle with a torch shining thru the plastic.
The coolant is a browny colour aswell.....i'm guessing oil mixing with the coolant??
So at the moment i'm guessing blown/cracked head gasket......is this also the cause of my footwell leaking problem or is this the heater aswell? I checked under the passenger foot well and the liquid is coming from where the white box thingy joins onto the firewall.
https://www.sau.com.au/forums/topic/49289-help-plz-read/#findComment-985626
Yep the heater core is leaking....****ing hell!! my car wreaks of coolant! no wonder i was getting dizzy! I checked the oil...no white shit in it but little clumps of tiny ass bubbles....not sure if this is normal. I heard you can bypass the heater by blocking off the heater pipe that goes into the firewall......i'm going to try and plumb it off somehow
Heater core under the dash is leaking??
Is there any white sh*t in your oil??
https://www.sau.com.au/forums/topic/49289-help-plz-read/#findComment-985664
you will find that the heater has a hole and the brown stuff in it is rust . the coolant probably hasnt been changed sisce it laeft nissan so the whole system ha srust in it ( all steel parts ) . check to see if there oil in the coolant , when you take the radiator cap off you will see it on the top . take the oil cap off and have a look if there any milky stuff on it , if there is or if you have oil in the radiator then its headgasket or cracked head .
https://www.sau.com.au/forums/topic/49289-help-plz-read/#findComment-985759
ok, i bypassed the heater as per predator's thread on how to bypass the heater. However there is still f*cking coolant leaking into the passenger footwell...would this be excess coolant that was stuck in the unit itself? is there any other way that coolant can get past the firewall??! i see two other metal pipes going into the firewall right near the heater hoses - are these for air cond?? should i plumb these off aswell?
https://www.sau.com.au/forums/topic/49289-help-plz-read/#findComment-986146
prolly shit still leaking out, try blowing out the hoses going into the firewall wit compresssed air to see if you can get most the coolant out, the coolant hoses are the only ones going through firewall into the dash, so youve still got an issue there.
https://www.sau.com.au/forums/topic/49289-help-plz-read/#findComment-986292
only 2 coolant hoses going in to the cabin , one bringing the coolant in and the other returning it so you must have coolant still in the heater core ( its a bustard of a job to take out if you want to fix it )
https://www.sau.com.au/forums/topic/49289-help-plz-read/#findComment-986397
Ok cool well at least i've blocked off the 2 hoses so no more coolant will come in....it seems as if the excess coolant stuck in the heater has stopped coming through aswell. Yeah i'm going to buy the part and install it myself; predator has a detailed thread on how to do it......and yes it will be a real prick to do and a waste of a whole day!
Thanks for the input so far guys, much appreciated.
https://www.sau.com.au/forums/topic/49289-help-plz-read/#findComment-986936
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
    • You don't have an R34 service manual for the body do you? Have found plenty for the engine and drivetrain but nothing else
    • If they can dyno them, get them dyno'd, make sure they're not leaking, and if they look okay on the dyno and are performing relatively well, put them in the car.   If they're leaking oil etc, and you feel so inclined, open them up yourself and see what you can do to fix it. The main thing you're trying to do is replace the parts that perish, like seals. You're not attempting to change the valving. You might even be able to find somewhere that has the Tein parts/rebuild kit if you dig hard.
    • Can you also make sure the invoices on the box (And none exist in the boxes) are below our import duty limits... I jest, there's nothing I need to actually purchase and order in. (Unless you can find me a rear diff carrier, brand new, for stupidly cheap, that is for a Toyota Landcruiser, HZJ105R GXL, 2000 year model...)
